Cucm to be connected with different cucme
techguy
Level 4
Level 4
I have one site where some ip phones are connected with our main cucm. But rest of the phones are created at local cucme (router 2951). Is it possible that 5 phones connected with CUCM can reach to local created phones???
9 Replies 9
Jaime Valencia
Yes, on CME configure a voip dial peer to CUCM and on CUCM configure that CME as an H323 GW.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Can i configure inter cluster trunk between cucm and cucme ?
No, that's for CUCM CLUSTERS only.
java
java
thnaks alot. Its much appreciated if someone can give me a template/example of how CUCM and CUCME (both cucm and router having cucme can reach each other via wan connection) can be inter-connected.
Do i need to create separate Router pattern, Router List, Route Group and Route Partition & CSS ?
On Gateway side, what will be the voip dial peer ?
You can find this document as a guide to configure the CallManager:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00808ebbfe.shtml
The dial-peer in the CME should be something like this:
dial-peer voice 1 voip
    destination-pattern xxxx
    session target ipv4:
    dtmf-relay h245-alphanumeric
    voice-class codec 1
Remember to add the h323-gateway voip bind srcaddr command under the interface that has the IP address that you configured in the CallManager.
Hope it helps, please rate if it does.
- Adrian.
The ip phones configured on CME Router ( not on the cucm, their tftp server is itself that cme router ) can call to the ip phones configured on cucm ?
Yes, as long as:
1.- A dialpeer VoIP is configured in your router towards the CUCM (just like the one I put in the previous post).
2.- The CME IP address is defined as an H.323 gateway in CallManager and has a CSS assigned to reach the CallManager endpoints.
- Adrian.
i've configured an ICT-non gatekeeper controlled and it works !!
i don't know if there are issues with this configuration or not .
