Community Helping Community
1729
Beginner
cucm to cube to sip trunk provider
I am Danny
I would like to ask help on how to configure cucm-cube-sip trunk provider or any basic guide for this?
the sip trunk provider only gave me:
cisco 1900 router
IP address
dial block.
available on our end is
BE6K - cucm, unity, IMPresnece
cisco 2911 router
thank you
17 REPLIES 17
Enthusiast
Well, for starters build a
Well, for starters build a SIP trunk in CUCM pointing to the IP of your CUBE that will be taking the calls.  On your CUBE you are going to need a dial-peer set that will push calls to your provider with a session target ipv4:x.x.x.x where that X's is the IP of your ITSP SIP provider.
There is a lot more to it than that, but at a basic level that would provide the groundwork.  Are you running CUBE authentication or no-auth?  H323-H323, SIP to SIP, SIP to H.323?
Here is a small excerpt from a lab that I am running.  Keep in mind, this is a lab and barebones.  It does the job for what I am wanting it to do...
voice service voip
 no ip address trusted authenticate
 srtp fallback
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 sip
  bind control source-interface FastEthernet0/1.192
  bind media source-interface FastEthernet0/1.192
  registrar server
  early-offer forced
voice translation-rule 1
 rule 1 /^512200\(2...$\)/ /\1/
dial-peer voice 3000 voip   <---- dial-peer to distant end CUBE
 destination-pattern 4693003...
 session protocol sipv2
 session target ipv4:172.168.1.2
 voice-class codec 1
dial-peer voice 2 voip  <---- dial-peer to CUCM
 preference 2
 destination-pattern 2...
 session target ipv4:192.168.1.102
 voice-class codec 1
Again, the above is a very VERY stripped down version of what I got running.  Those are some of the key components though and will obviously change based on someone else's configuration, especially for a real world environment.
Highlighted
Beginner
Hi Brandon thank you for the
Hi Brandon
thank you for the reply
I am not running cube authentication, our SIP provider just gave us the IP and dial block and they said the rest of the configuration is done from our part :(. I heard I have to use CUBE for this kind of setup which is I really don't know yet because it is my first time to setup a CUBE.
example
CUCM (10.1.45.3)  ->  (10.1.45.13) CUBE (192.168.50.2)  ->  (192.168.50.1) SIP Trunk provider (10.202.1xx.xxx)
also the Sip provider ask me what is my signaling IP going to them? I hope I could find answer above my diagram :(
Enthusiast
What?  It's SIP...unless they
What?  It's SIP...unless they are talking about early offer and delayed offer.  That all depends on what they want...You might want to talk to their managers, they are supposed to let you know what they want and not just throw you into the lions den to figure out what they are doing on their end.
Beginner
Hi BrandonI would like to
Hi Brandon
I would like to show you my CUBE logs I think I have already set it up but maybe I missed some points :(
Outgoing call Logs
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.06 15:14:55 =~=~=~=~=~=~=~=~=~=~=~=
Feb  6 06:57:49.446: //-1/9DC1DF000000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=200
   ----- ccCallInfo IE subfields -----
   cisco-ani=200
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=08228777303055942
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  6 06:57:49.446: //-1/9DC1DF000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2A037C8C, Call Info(
   Calling Number=200,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=08228777303055942(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=96
Feb  6 06:57:49.446: //-1/9DC1DF000000/CCAPI/ccCheckClipClir:
   In: Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Feb  6 06:57:49.446: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 06:57:49.446: :cc_get_feature_vsa malloc success
Feb  6 06:57:49.446:  cc_get_feature_vsa count is 1
Feb  6 06:57:49.446: :FEATURE_VSA attributes are: feature_name:0,feature_time:821486952,feature_id:94
Feb  6 06:57:49.446: //96/9DC1DF000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=08228777303055942(TON=Unknown, NPI=Unknown))
Feb  6 06:57:49.446: //96/9DC1DF000000/CCAPI/cc_process_call_setup_ind:
   Event=0x30CF3E20
Feb  6 06:57:49.446: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 08228777303055942
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccCallSetContext:
   Context=0x40A03810
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 96 with tag 100 to app "_ManagedAppProcess_Default"
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccCallProceeding:
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=200, Params=0x40A04C08, Progress Indication=NULL(0)
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccCheckClipClir:
   Destination Pattern=0822877730......., Called Number=08228777303055942, Digit Strip=FALSE
   Redirect Number=, Display Info=DEMO
   Account Number=200, Final Destination Flag=TRUE,
   Guid=9DC1DF00-0001-0000-0000-003E0A32A8C0, Outgoing Dial-peer=200
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=200
   cisco-ani=200
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2A037C8C, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=200,(Calling Name=DEMO)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=08228777303055942(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=200, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb  6 06:57:49.450: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 06:57:49.450: :cc_get_feature_vsa malloc success
Feb  6 06:57:49.450:  cc_get_feature_vsa count is 2
Feb  6 06:57:49.450: :FEATURE_VSA attributes are: feature_name:0,feature_time:821486728,feature_id:95
Feb  6 06:57:49.450: //97/9DC1DF000000/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb  6 06:57:49.450: //97/9DC1DF000000/CCAPI/ccCallSetContext:
   Context=0x40A04BB8
Feb  6 06:57:49.450: //96/9DC1DF000000/CCAPI/ccSaveDialpeerTag:
Feb  6 06:57:49.450: //97/9DC1DF000000/CCAPI/cc_api_call_proceeding:
   Interface=0x2A037C8C, Progress Indication=NULL(0)
Feb  6 06:57:49.954: //97/9DC1DF000000/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x2A037C8C, Call Id=97
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Feb  6 06:57:49.954: //96/9DC1DF000000/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Feb  6 06:57:49.954: //97/9DC1DF000000/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=97
Feb  6 06:57:49.954: //97/9DC1DF000000/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Feb  6 06:57:49.954: //97/9DC1DF000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x2A037C8C, Tag=0x0, Call Id=97,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb  6 06:57:49.954: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 06:57:49.954: :cc_free_feature_vsa freeing 30F6E480
Feb  6 06:57:49.954:  vsacount in free is 1
Feb  6 06:57:49.954: //96/9DC1DF000000/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb  6 06:57:49.958: //96/9DC1DF000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2A037C8C, Tag=0x0, Call Id=96,
Feb  6 06:57:49.958: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 06:57:49.958: :cc_free_feature_vsa freeing 30F6E560
Feb  6 06:57:49.958:  vsacount in free is 0
Incoming call Logs
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.06 15:16:01 =~=~=~=~=~=~=~=~=~=~=~=
Feb  6 07:00:03.190: //98/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Feb  6 07:00:03.190: //-1/9BB67D868127/CCAPI/cc_api_display_ie_subfields:
   cisco-username=0823055942
   cisco-ani=0823055942
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0822877730
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb  6 07:00:03.190: //-1/9BB67D868127/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=0823055942,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0822877730(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=98
Feb  6 07:00:03.190: //-1/9BB67D868127/CCAPI/ccCheckClipClir:
   In: Calling Number=0823055942(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=0823055942(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  6 07:00:03.190: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  6 07:00:03.190: :cc_get_feature_vsa malloc success
Feb  6 07:00:03.190:  cc_get_feature_vsa count is 1
Feb  6 07:00:03.190: :FEATURE_VSA attributes are: feature_name:0,feature_time:821486952,feature_id:96
Feb  6 07:00:03.190: //98/9BB67D868127/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=0823055942(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0822877730(TON=Unknown, NPI=Unknown))
Feb  6 07:00:03.190: //98/9BB67D868127/CCAPI/cc_process_call_setup_ind:
   Event=0x30CF3E20
Feb  6 07:00:03.190: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Feb  6 07:00:03.190: //98/9BB67D868127/CCAPI/ccCallSetContext:
   Context=0x40A05F60
   >>>>CCAPI handed cid 98 with tag 100 to app "_ManagedAppProcess_Default"
Feb  6 07:00:03.190: //98/9BB67D868127/CCAPI/ccCallProceeding:
Feb  6 07:00:03.190: //98/9BB67D868127/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Feb  6 07:00:03.234: //98/9BB67D868127/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2A037C8C, Tag=0x0, Call Id=98,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Feb  6 07:00:03.234: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  6 07:00:03.234: :cc_free_feature_vsa freeing 30F6E560
Feb  6 07:00:03.234:  vsacount in free is 0
Inbound call failed with
Inbound call failed with Cause Value=1
Indicates that the destination requested by the calling user cannot be reached because the number is unassigned.
Outbound call failed with Cause Value=38 (Network failure. )
Indicates that the network is not functioning correctly and that the condition is likely to last for an extended period.
Please share "show run" from your CUBE.
Also below debugs output for both incoming and outgoing calls from CUBE.
Router(config)# logging buffer 5000000
Router#clear log
Router# deb voice ccapi inout
Router#deb ccsip mes
Make tests calls now.
Router#show log---->take entire output of this and attach it here.
Beginner
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.09 16:05:30 =~=~=~=~=~=~=~=~=~=~=~=
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
//90/4B342D000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
//90/4B342D000000/SIP/Info/sipSPISendInvite: Associated container=0x2A4F7674 to Invite
//90/4B342D000000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
//90/4B342D000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
//90/4B342D000000/SIP/Transport/sipSPITransportSendMessage: msg=0x314763B0, addr=10.1.45.20, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x24E20C4C
//90/4B342D000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
//90/4B342D000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
//-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:10.1.45.20, rport:5060 with laddr:
//90/4B342D000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x314763B0
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x314763B0, addr=10.1.45.20, port=5060, local_addr=, connId=2 for UDP
//90/4B342D000000/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
//-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
//90/4B342D000000/SIP/State/sipSPIChangeState: 0x40953AB0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
//-1/xxxxxxxxxxxx/SIP/Error/HandleUdpSocketWrites: Send failed errno 261
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4055DCD4, addr=192.168.50.10, port=41263, local_addr=, connid=2, transport=TCP
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
//87/41AAC5000000/SIP/State/sipSPIChangeState: 0x4095E900 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)INVITE sip:08228777303055942@192.168.50.1:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.50.10:5060;branch=z9hG4bK3d286eb43f
From: "DEMO" <sip:200@192.168.50.10>;tag=63~7f88b1b9-f68d-4857-b8e0-e411cd112197-23099691
To: <sip:08228777303055942@192.168.50.1>
Date: Mon, 09 Feb 2015 07:57:15 GMT
Call-ID: 41aac500-4d81685b-3e-a32a8c0@192.168.50.10
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOT
//-1/xxxxxxxxxxxx/SIP/Info/udpsock_close_connect: Socket fd: 1 closed for connid 2 with remote port: 5060IFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:192.168.50.10:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1101710592-0000065536-0000000062-0171092160
Session-Expires:  1800
P-Asserted-Identity: "DEMO" <sip:200@192.168.50.10>
Remote-Party-ID: "DEMO" <sip:200@192.168.50.10>;party=calling;screen=yes;privacy=off
Contact: <sip:200@192.168.50.10:5060;transport=tcp>;video;audio
Max-Forwards: 70
Content-Length: 0
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
//89/4B342D000000/CCAPI/ccCallReleaseResources:
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4095E900) with key=[87] to table
Feb  9 07:49:17.102: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.50.10,Port 41263, Transport 2, SentBy Port 5060
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()release reserved xcoding resource.
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 192.168.50.1
Feb  9 07:49:17.102: //-1/41AAC5000000/SIP/State/sipSPIChangeState: 0x4095E900 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Feb  9 07:49:17.102: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 192.168.50.1
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x2920A79C) found for sip_user: 08228777303055942
%SYS-3-CPUHOG: Task is running for (2168)msecs, more than (2000)msecs (0/0),process = AFW_application_process.
-Traceback= 0x21144C68z 0x2114688Cz 0x21146830z 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24B11F34z 0x24B12934z 0x24A8BBF4z 0x25050B84z 0x25055760z 0x250559B0z 0x2508A71Cz 0x25051120z 0x25059968z
//90/4B342D000000/CCAPI/ccCallSetAAA_Accounting:
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to DEMO
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 200
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.Accounting=0, Call Id=90
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4095E900 key=41aac500-4d81685b-3e-a32a8c0@192.168.50.1008228777303055942
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 08228777303055942
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 200
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name DEMO, number 200, Calling oct3 0x00, oct_3a 0x81, Called number 08228777303055942
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:192.168.50.10:5060, Host:192.168.50.10
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 200
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
%SYS-3-CPUHOG: Task is running for (4564)msecs, more than (2000)msecs (0/0),process = AFW_application_process.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C9F710z 0x24A86190z 0x25027CACz 0x25027FB4z 0x25050BBCz 0x25055760z 0x250559B0z 0x2508A71Cz 0x25051120z 0x25059968z
//90/4B342D000000/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Peer tag 300 matched for incoming call
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
%SYS-3-CPUHOG: Task is running for (6572)msecs, more than (2000)msecs (0/0),process = AFW_application_process.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24B11F34z 0x24B1271Cz 0x24A861E0z 0x25027CACz 0x25027FB4z 0x25050BBCz 0x25055760z 0x250559B0z 0x2508A71Cz 0x25051120z //90/4B342D000000/CCAPI/ccCallDisconnect:
//-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
//87/41AAC5000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 09 Feb 2015 07:49:18 GMT
CSeq: 101 CANCEL
Content-Length: 0
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
//90/4B342D000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
//90/4B342D000000/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2120, posted event:E_STSL_PASS_ST_PARAMS, reason:4
Configured SE:1800, Configured Min-SE:1800
//90/4B342D000000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:1638538 ConnTime 0
//90/4B342D000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x4055E3B0, Tag=0x0, Call Id=90,
:cc_free_feature_vsa freeing 30024C68
 vsacount in free is 3
//90/4B342D000000/SIP/State/sipSPIChangeState: 0x40953AB0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
//90/4B342D000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x40953AB0
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 200
Called Number            : 08228777303055942
Source IP Address (Sig  ): 10.1.45.3
Destn SIP Req Addr:Port  : 10.1.45.20:5060
Destn SIP Resp Addr:Port : 10.1.45.20:5060
Destination Name         : 10.1.45.20
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 200
//90/4B342D000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 5A
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteCon
%SYS-3-CPUHOG: Task is running for (2004)msecs, more than (2000)msecs (1/0),process = CCSIP_SPI_CONTROL.
-Traceback= 0x21144C2Cz 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C7E33Cz 0x24C7FF24z 0x24C56D2Cz 0x24C57DA0z 0x24DA246Cz 0x24DA2910z 0x23588E0Cz 0x23588DF0z textFromTable: Context for key=[90] removed.
//90/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
//90/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x40953AB0 key=FBA3F3EE-AF6611E4-8117B06D-73276674@10.1.45.3
//90/4B342D000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
//90/4B342D000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
//90/4B342D000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 40953AB0
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[90]
//88/41AAC5000000/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
//88/41AAC5000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
//-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECTterminal monitor
//88/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
//88/41AAC5000000/SIP/Info/Session-Timer/sipSTSLMain:
//88/41AAC5000000/SIP/Info/act_sentinvite_disconnect: Received POTS Disconnect - Holding CANCEL till we receive a response from remote end.
//87/41AAC5000000/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
//87/41AAC5000000/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Received:
CANCEL sip:08228777303055942@192.168.50.1:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.50.10:5060;branch=z9hG4bK3e9db6a06
From: "DEMO" <sip:200@192.168.50.10>;tag=64~7f88b1b9-f68d-4857-b8e0-e411cd112197-23099693
Date: Mon, 09 Feb 2015 07:57:31 GMT
Call-ID: 4b342d00-4d81686b-3f-a32a8c0@192.168.50.10
CSeq: 101 CANCEL
Max-Forwards: 70
Content-Length: 0
//89/4B342D000000/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x4094E388
//89/4B342D000000/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[89], src[2]
//-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer: Failed AV set
//89/4B342D000000/SIP/State/sipSPIChangeState: 0x4094E388 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
//89/4B342D000000/SIP/Transport/sipSPISendCance
%SYS-3-CPUHOG: Task is running for (2004)msecs, more than (2000)msecs (0/0),process = CCSIP_SPI_CONTROL.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C279C0z 0x24C44710z 0x24C55D6Cz lResponse: Sending CANCEL Response to the transport layer
//89/4B342D000000/SIP/Transport/sipSPITransportSendMessage: msg=0x40A8B45C, addr=192.168.50.10, port=41263, sentBy_port=5060, local_addr=, is_req=0, transport=2, switch=0, callBack=0x0
//89/4B342D000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
//89/4B342D000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x40A8B45C, addr=192.168.50.10, port=41263, local_addr=, connId=2 for TCP
//89/4B342D000000/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
//89/4B342D000000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
//89/4B342D000000/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
//89/4B342D000000/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
//89/4B342D000000/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4055E3B0, Call Id=89
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
%SYS-3-CPUHOG: Task is running for (4004)msecs, more than (2000)msecs (1/0),process = CCSIP_SPI_CONTROL.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C83974z 0x24BF9754z 0x24C4474Cz 0x24C55D6Cz E_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
//89/4B342D000000/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
//89/4B342D000000/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
//89/4B342D000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 09 Feb 2015 07:49:34 GMT
CSeq: 101 CANCEL
Content-Length: 0
//87/41AAC5000000/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
//87/41AAC5000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4095E900 key=41aac500-4d81685b-3e-a32a8c0@192.168.50.10FA2B40-110D
//87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
//87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:487, container:2A4F75C4
//87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
//87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_INVALID_PEER_EVENT, SE Value:0, SE Refresher:none, Min-SE Value:0, flags:2120
//87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:1, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
//87/41AAC5000000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
//87/41AAC5000000/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
//87/41AAC5000000/SIP/Info/sipSPISendInviteResponse: Associated container=0x2A4F75C4 to Invite Response 487
//87/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: msg=0x3002DB00, addr=192.168.50.10, port=41263, sentBy_port=5060, local_addr=, is_req=0, transport=2, switch=0, callBack=0x24E21898
//87/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
//87/41AAC5000
-Traceback= 0x21144C68z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24E1D99Cz 0x24E1F14Cz 0x24C2D350z 0x24C438B4z 0x24C56D2Cz 0x24C57DA0z 0x24DA246Cz 0x24DA2910z 0x23588E0Cz 0x23588DF0z 000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3002DB00, addr=192.168.50.10, port=41263, local_addr=, connId=2 for TCP
//87/41AAC5000000/SIP/Info/sentRequestCancelDisconnecting: Sent a 487 Request Cancelled
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:08228777303055942@192.168.50.1>;tag=FA2B40-110D
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=16
Content-Length: 0
deb ccsip messages
//89/4B342D000000/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
//89/4B342D000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4094E388 key=4b342d00-4d81686b-3f-a32a8c0@192.168.50.10FA3860-0
//89/4B342D000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
//89/4B342D000000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:487, container:2A4F87A4
//89/4B342D000000/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
//89/4B342D000000/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:81, posted event:E_STSL_INVALID_PEER_EVENT, reason:3
//89/4B342D000000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
//89/4B342D000000/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
//89/4B342D000000/SIP/Info/sipSPISendInviteResponse: Associated container=0x2A4F87A4 to Invite Response 487
//89/4B342D000000/SIP/Transport/sipSPITransportSendMessage: msg=0x3002DB00, addr=192.168.50.10, port=41263, sentBy_port=5060, local_addr=, is_req=0, transport=2, switch=0, callBack=0x24E21898
-Traceback= 0x21144C70z 0x2114688Cz 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24E19540z 0x24E1E528z 0x24E1F14Cz 0x24C2D350z 0x24C438B4z 0x24C56D2Cz 0x24C57DA0z 0x24DA246Cz 0x24DA2910z 0x23588E0Cz g send for msg=0x3002DB00, addr=192.168.50.10, port=41263, local_addr=, connId=2 for TCP
//89/4B342D000000/SIP/Info/sentRequestCancelDisconnecting: Sent a 487 Request Cancelled
Sent:
To: <sip:08228777303055942@192.168.50.1>;tag=FA3860-0
CSeq: 101 INVITE
Content-Length: 0
Received:
ACK sip:08228777303055942@192.168.50.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
//87/41AAC5000000/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4095E900
//87/41AAC5000000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:1640306 ConnTime 0
//87/41AAC5000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4055E3B0, Tag=0x0, Call Id=87,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
-Traceback= 0x21144C00z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24B11F34z 0x24B1271Cz 0x24AC9058z 0x24D291C4z 0x24C83A14z 0x24C42530z 0x24C55D6Cz ll_disconnect_done:
:cc_free_feature_vsa freeing 30024D48
 vsacount in free is 2
//87/41AAC5000000/SIP/State/sipSPIChangeState: 0x4095E900 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
//87/41AAC5000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4095E900
TCP Sockets Used         : YES
Source IP Address (Sig  ): 192.168.50.1
Destn SIP Req Addr:Port  : 192.168.50.10:5060
Destn SIP Resp Addr:Port : 192.168.50.10:41263
Destination Name         : 192.168.50.10
//87/41AAC5000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.50.1
Source IP Port    (Media): 31226
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
//87/41AAC5000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing cal
-Traceback= 0x21144C68z 0x2114688Cz 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C7DE14z 0x24C7FE84z 0x24C42530z 0x24C55D6Cz l id 57
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[87] removed.
//87/41AAC5000000/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
//87/41AAC5000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4095E900 key=41aac500-4d81685b-3e-a32a8c0@192.168.50.1008228777303055942
//87/41AAC5000000/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
//87/41AAC5000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4095E900 key=41aac500-4d81685b-3e-a32a8c0@192.168.50.10FA2B40-110D
//87/41AAC5000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
//87/41AAC5000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
//87/41AAC5000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4095E900
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[87]
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
//89/4B342D000000/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4094E388
//89/4B342D000000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:1640846 ConnTime 0
//89/4B342D000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4055E3B0, Tag=0x0, Call Id=89,
-Traceback= 0x21144C68z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24B11F34z 0x24B1271Cz 0x24AC9058z 0x24D291C4z 0x24C83A14z 0x24C42530z 0x24C55D6Cz _disconnect_done:
:cc_free_feature_vsa freeing 30024B88
//89/4B342D000000/SIP/State/sipSPIChangeState: 0x4094E388 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
//89/4B342D000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4094E388
//89/4B342D000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 20580
//89/4B342D000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing c
%SYS-3-CPUHOG: Task is running for (4004)msecs, more than (2000)msecs (0/0),process = CCSIP_SPI_CONTROL.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237BBB0z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C7DE14z 0x24C7FE84z 0x24C42530z 0x24C55D6Cz all id 59
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[89] removed.
//89/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
//89/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4094E388 key=4b342d00-4d81686b-3f-a32a8c0@192.168.50.1008228777303055942
//89/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
//89/4B342D000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4094E388 key=4b342d00-4d81686b-3f-a32a8c0@192.168.50.10FA3860-0
//89/4B342D000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
//89/4B342D000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
//89/4B342D000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4094E388
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[89]ug voice ccapi inout
//88/41AAC5000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
//88/41AAC5000000/SIP/Info/sipSPISendInvite: Associated container=0x2A4F8014 to Invite
//88/41AAC5000000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
//88/41AAC5000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
//88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: msg=0x30F68B18, addr=10.1.45.20, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
//88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
//88/41AAC5000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting UDP conn create request for addr=10.1.45.20, port=5060, context=0x30EF3B28
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x2A1F8830,addr=10.1.45.20, port=5060
Wait Conn Timer started for 5000 msec
//-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x2A1F8830, connid=-1, addr=10.1.45.20, port=5060, local_addr=, transport=UDP
//-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x409591D8 with connection=0x2A1F8830
-Traceback= 0x21144C4Cz 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24E1F2B0z 0x24C2F298z 0x24C4A640z 0x24C57A18z 0x24DA25A8z 0x24DA2920z 0x23588E0Cz 0x23588DF0z ge: Deferred sending msg=0x30F68B18
//88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: msg=0x409CAD50, addr=10.1.45.20, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
//88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Cannot proceed to send msg-0x409CAD50 immediately. Msg in send context-0x30F68B18
//88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Enqueued msg-0x409CAD50 into transport pending Q
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 58
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionCreated: context=0x30EF3B28
//-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: gConnTab=0x30EF3B28, addr=10.1.45.20, port=5060, local_addr=, connid=2, transport=UDP
//-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:10.1.45.20, port:5060 local_addr= local_port=60501
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x2A1F8830,addr=10.1.45.20, port=5060
//-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x2A1F8830, connid=2 state to established. local_addr=, local_port=60501
//88/41AAC5000000/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=0clear log
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 63
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x30F68B18, addr=10.1.45.20, port=5060, local_addr=, connId=2 for UDP
//88/41AAC5000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x409CAD50
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x409CAD50, addr=10.1.45.20, port=5060, local_addr=, connId=2 for UDP
//88/41AAC5000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:08228777303055942@10.1.45.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.45.3:5060;branch=z9hG4bK2525A3
Remote-Party-ID: "DEMO" <sip:200@10.1.45.3>;party=calling;screen=yes;privacy=off
To: <sip:08228777303055942@10.1.45.20>
Date: Mon, 09 Feb 2015 07:49:55 GMT
Call-ID: FBA1834E-AF6611E4-8111B06D-73276674@10.1.45.3
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1423468195
Contact: <sip:200@10.1.45.3:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 0
Sent:
Date: Mon, 09 Feb 2015 07:49:58 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1423468198
Expires: 180
Max-Forwards: 69
Session-Ex
%SYS-3-CPUHOG: Task is running for (2004)msecs, more than (2000)msecs (1/0),process = CCSIP_UDP_SOCKET.
-Traceback= 0x21144C14z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C7A5B4z 0x24DA599Cz 0x24DA5B00z 0x23588E0Cz 0x23588DF0z pires:  1800
Content-Length: 0
//88/41AAC5000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x30F68B18
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 57
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWSocketException: context=0x30EF3B28
//-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessSocketExceptions: gConnTab=0x30EF3B28, addr=10.1.45.20, port=5060, local_addr=, connid=2, transport=UDP
//-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting UDP conn close for addr=10.1.45.20, port=5060, local_addr=, connid=2
//-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x2A1F8830, connid=2, addr=10.1.45.20, port=5060, local_addr=, transport=UDP
//-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 54
//-1/xxxxxxxxxxxx/SIP/Error/act_socket_send_msg_failure: Send Error to 10.1.45.20:5060 for transport UDP
//88/41AAC5000000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:1642255 ConnTime 0
//88/41AAC5000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x4055E3B0, Tag=0x0, Call Id=88,
:cc_free_feature_vsa freeing 30024E28
//88/41AAC5000000/SIP/State/sipSPIChangeState: 0x409591D8 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
//88/41AAC5000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x409591D8
//88/41AAC5000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 58
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[88] removed.
//88/41AAC5000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
-Traceback= 0x21144C68z 0x2114688Cz 0x2237B9F4z 0x2237A030z 0x2242E5A4z 0x2242E6B4z 0x24C7D880z 0x24C80250z 0x24E13A0Cz 0x24C55D6Cz romTable: Deleting from table. ccb=0x409591D8 key=FBA1834E-AF6611E4-8111B06D-73276674@10.1.45.3
//88/41AAC5000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
//88/41AAC5000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
//88/41AAC5000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 409591D8
//-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[88]no termin ;;        terminal monitor deb ccsip messages ug voice ccapi inoutccapi inout
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIContinueNewMsgInvite: Calling name DEMO, number 200, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 08228777303055942, oct3 0x00
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIValidateRequestUri: Not Enabled
Feb  9 07:49:17.106: //-1/41AAC5000000/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:2A4F7B44
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: none
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2001
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <sip:192.168.50.10:5060>, duration = 500
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
Feb  9 07:49:17.106: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPIDoQoSNegotiationWithNoMediaLine: Local Precondition: 1, Remote Precondition: 1
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 87, Peer CallID 0, sdp 0x2A234A68 channels 0x4095FE54
Feb  9 07:49:17.106: //87/41AAC5000000/SIP/Info/copy_channels:
 callId 87 size 0 ptr 0x401FAB24)
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
 CCB t38 version 0 ipip_caps version 0
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Delayed media case...creating new stream
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 192.168.50.1
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.50.1
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 31226 for stream 1
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=31226
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g729r8 codecbytes :20, ptime: 20
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 41aac500-4d81685b-3e-a32a8c0@192.168.50.10
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPI_ipip_store_channel_info: negotiated dtmf not available, using dialpeer config dtmf = 0
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIShrlCall: Check peer: 300 for Shared-Line call, callid: 87
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Feb  9 07:49:17.110: //-1/41AAC5000000/CCAPI/cc_api_display_ie_subfields:
   cisco-username=200
   cisco-ani=200
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb  9 07:49:17.110: //-1/41AAC5000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4055E3B0, Call Info(
   Incoming Dial-peer=300, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=87
Feb  9 07:49:17.110: //-1/41AAC5000000/CCAPI/ccCheckClipClir:
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  9 07:49:17.110: :cc_get_feature_vsa malloc success
Feb  9 07:49:17.110:  cc_get_feature_vsa count is 1
Feb  9 07:49:17.110: :FEATURE_VSA attributes are: feature_name:0,feature_time:805457232,feature_id:82
Feb  9 07:49:17.110: //87/41AAC5000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS_DELAYED_MEDIA
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 57 to table
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:2A4F8384
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPISendInviteResponse: Associated container=0x2A4F8384 to Invite Response 100
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: msg=0x2A5CC788, addr=192.168.50.10, port=41263, sentBy_port=5060, local_addr=, is_req=0, transport=2, switch=0, callBack=0x0
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A5CC788, addr=192.168.50.10, port=41263, local_addr=, connId=2 for TCP
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/State/sipSPIChangeState: 0x4095E900 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
Feb  9 07:49:17.110: //87/41AAC5000000/SIP/Info/sipSPIProcessContactInfo: Previous Hop 192.168.50.10:5060
Feb  9 07:49:17.110: //87/41AAC5000000/CCAPI/cc_process_call_setup_ind:
   Event=0x407ACA30
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Feb  9 07:49:17.110: //87/41AAC5000000/CCAPI/ccCallSetContext:
   Context=0x2A574B68
   >>>>CCAPI handed cid 87 with tag 300 to app "_ManagedAppProcess_Default"
Feb  9 07:49:17.110: //87/41AAC5000000/CCAPI/ccCallProceeding:
Feb  9 07:49:17.110: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Feb  9 07:49:17.114: //87/41AAC5000000/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=200, Params=0x2A5786B0, Progress Indication=NULL(0)
Feb  9 07:49:17.114: //87/41AAC5000000/CCAPI/ccCheckClipClir:
   Guid=41AAC500-0001-0000-0000-003E0A32A8C0, Outgoing Dial-peer=200
Feb  9 07:49:17.114: //87/41AAC5000000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=200
   cisco-ani=200
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb  9 07:49:17.114: //87/41AAC5000000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4055E3B0, Interface Type=3, Destination=, Mode=0x0,
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  9 07:49:17.114: :cc_get_feature_vsa malloc success
Feb  9 07:49:17.114:  cc_get_feature_vsa count is 2
Feb  9 07:49:17.114: :FEATURE_VSA attributes are: feature_name:0,feature_time:805457456,feature_id:83
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x409591D8) with key=[88] to table
Feb  9 07:49:17.114: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Feb  9 07:49:17.114: //88/000000000000/SIP/State/sipSPIChangeState: 0x409591D8 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Feb  9 07:49:17.114: //88/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Feb  9 07:49:17.114: //88/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
 This a IPIP call: NULL peer_channel - peer_channels = 0x0, peer_param = 0x2A4F881C, callID= 88, peer_callID = 87
Feb  9 07:49:17.114: //88/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 10.1.45.20 target_port : 5060
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [200]
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 168)
Feb  9 07:49:17.114: //87/41AAC5000000/SIP/Info/ccsip_event_handler:
 ccsip_event_handler: peer ID 88 chans 0x40ABA2D0 event 168 flags 0x40201C 0x100 0x201 data 0x40ABA2D0
 ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 88 chans 0x40ABA2D0 event 168 flags 0x40201C 0x100 0x201 data 0x40ABA2D0, type = 1
Feb  9 07:49:17.114: //87/41AAC5000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
Feb  9 07:49:17.114: //87/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
Feb  9 07:49:17.114: //87/41AAC5000000/SIP/Info/Session-Timer/sipSTSLMain:
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
Feb  9 07:49:17.114: //88/41AAC5000000/CCAPI/ccIFCallSetupRequestPrivate:
Feb  9 07:49:17.114: //88/41AAC5000000/CCAPI/ccCallSetContext:
   Context=0x2A578660
Feb  9 07:49:17.114: //87/41AAC5000000/CCAPI/ccSaveDialpeerTag:
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 58 to table
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=87
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/preprocessSetup:
 This is a not a SIGO Call -, could be DM call
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_call_setup: No video caps posted by peer
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_call_setup: xcoder high-density disabled
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_call_setup: Flow Mode set to FLOW_THROUGH
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 88, channels 0x0 caps 0x40AA29E4
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_setOptionTagInfo: Option Tag Rel1xx value is 1
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 10.1.45.3
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
spmcucsgateway#nfo/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPI_ipip_set_diversion_header: No diversion header recvd from container
spmcucsgateway#
spmcucsgateway#
spmcucsgateway#
spmcucsgateway#_address_to_bind: calling ip_best_local_address()
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
spmcucsgateway#
spmcucsgateway#
spmcucsgateway#
spmcucsgateway#xxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 10.1.45.3
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x409591D8 key=FBA1834E-AF6611E4-8111B06D-73276674@10.1.45.3
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = FBA1834E-AF6611E4-8111B06D-73276674@10.1.45.3
Feb  9 07:49:17.114: //88/41AAC5000000/CCAPI/cc_api_call_proceeding:
   Interface=0x4055E3B0, Progress Indication=NULL(0)
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.1.45.20,Port 5060, Transport 1, SentBy Port 5060
Feb  9 07:49:17.114: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:2A4F8014
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2001
Feb  9 07:49:17.114: //88/41AAC5000000/SIP/Info/Session-Timer/sipSTSLSRReqPassPeerEventHndlr: session timer negotiated end to end
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Info/Session-Timer/sipSTSLMain:
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
Feb  9 07:49:17.118: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Info/sipSPISendInvite: Associated container=0x2A4F8014 to Invite
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: msg=0x3002D9F4, addr=10.1.45.20, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x24E20C4C
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb  9 07:49:17.118: //88/41AAC5000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Feb  9 07:49:17.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting UDP conn create request for addr=10.1.45.20, port=5060, context=0x30EF3B28
Feb  9 07:49:17.118: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x40695E28,addr=10.1.45.20, port=5060
The logs, are overlapped, i
The logs, are overlapped, i think you have taken them with term mon.
Could you follow below steps:
Router(config)#no logging console
Router#term no mon
Router#debug voice ccapi inout
Now log the putty session (link:http://www.viktorious.nl/2013/01/14/putty-log-all-session-output/
https://my.kualo.com/uk/knowledgebasekualo.php?kbcat=0&article=888)
Router# clear log---->clear existing buffer logs
Make a test call and create the issue(mention here calling and called numbers)
Router# show log--->send me the log file.
Beginner
Hi Aramared i would like to
Hi Aramared
i would like to ask for some verification, what are the needed requirements should i ask from the SIP provider ? because they only give me this details from there side and they said the rest is ours :(
SIP Provider ( cisco 1900 series )
SVC IP: SIP trunk WAN IP ( int g0/0 )
Private IP: 10.1.45.20 ( int g0/1 )
Dial Block : 0822877730
Signalling IP: 10.1.45.3 ( this is the IP they ask from us to be used for signalling)
is there anything we should ask them other than this parameters they gave us? :(
We need to ask them, whether
We need to ask them, whether are we using here SIP trunk with authentication or without authentication, on CUBE towards Service provider, because i don't see any authentication config under sip-ua in the "show run" which you have attached here.
++If SIP trunk with authentication is used, we need to know username, password and realm(not mandatory) for the same.
++second what should be the IP, we should be using on our CUBE, for signalling and media, so that provider accept the call.
Beginner
Hi aramared thank you for the
Hi aramared
thank you for the response
++ our sip trunk has no authentication
++ I dont know what signalling IP should we give them, is it the IP from CUBE interface facing the SIP provider router Interface or is it the CUCM IP we should give them?
Please take a look of the diagram what IP should we give them for signaling :) .
CUCM ( LAN: 192.168.50.10) - ( int g0/1: 192.168.50.1) CUBE ( int g0/0: 10.1.45.3) - ( int g0/0: 10.1.45.20) Sip Provider ( SBC IP:10.202.143.212) ?
It's the IP address on the
It's the IP address on the CUBE which is pointing to SIP provider router interface.
Beginner
we've already gave it to them
we've already gave it to them , @ my cube configuration you can see the IP 10.1.45.3 is at int g0/0 pointed to there router IP 10.1.45.20.
aramared is it ok if I could have a Skype call to you? :) maybe a little help with my configuration
Hi,When you are not using sip
When you are not using sip trunk with Authentication, there is less config which needs to be made(sip media and signalling bind, dial-peers etc). If you can send me below info, i can check and tell the config here.
Router#term no mon
Router#undebug all
Beginner
Hi aramared I followed the
Hi aramared
I followed the commands you give me
Attaching also the outputs :) thank you
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.02.10 13:00:11 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
CUBE>en
Password:
CUBE#clea
CUBE#clear log
CUBE#clear logging
Clear logging buffer [confirm]
CUBE#deb
CUBE#debug voice
CUBE#debug voice ccap
CUBE#debug voice ccapi inou
CUBE#debug voice ccapi inout
voip ccapi inout debugging is on
CUBE#deb
CUBE#debug ccsi
CUBE#debug ccsip mess
CUBE#debug ccsip messages
SIP Call messages tracing is enabled
CUBE#te
CUBE#ter
CUBE#terminal no moni
CUBE#terminal no monitor
CUBE#
CUBE#
CUBE#
CUBE#show      deb
CUBE#debug       undeb
CUBE#undebug all
CUBE#undebug all
All possible debugging has been turned off
CUBE#show lo
CUBE#show log
CUBE#show log?
logging  login
CUBE#show logging
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 177 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 177 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 42 message lines logged
Log Buffer (8192 bytes):
 --More--
Feb 10 04:43:32.095: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0823055942@192.168.50.1:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.50.10:5060;branch=z9hG4bK764c21c81
From: "DEMO" <sip:200@192.168.50.10>;tag=9~7f88b1b9-f68d-4857-b8e0-e411cd112197-23459452
To: <sip:0823055942@192.168.50.1>
Date: Tue, 10 Feb 2015 04:51:55 GMT
Call-ID: 880b2d00-4d918e6b-8-a32a8c0@192.168.50.10
Min-SE:  1800
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 2282433792-0000065536-0000000008-0171092160
 --More--         P-Asserted-Identity: "DEMO" <sip:200@192.168.50.10>
Max-Forwards: 70
Content-Length: 0
Feb 10 04:43:32.095: //-1/880B2D000000/CCAPI/cc_api_display_ie_subfields:
   cisco-username=200
   ----- ccCallInfo IE subfields -----
   cisco-ani=200
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0823055942
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
 --More--            cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb 10 04:43:32.099: //-1/880B2D000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4058B770, Call Info(
   Calling Number=200,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0823055942(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2
Feb 10 04:43:32.099: //-1/880B2D000000/CCAPI/ccCheckClipClir:
   In: Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
 --More--         Feb 10 04:43:32.099: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 10 04:43:32.099: :cc_get_feature_vsa malloc success
Feb 10 04:43:32.099:  cc_get_feature_vsa count is 1
Feb 10 04:43:32.099: :FEATURE_VSA attributes are: feature_name:0,feature_time:709956296,feature_id:2
Feb 10 04:43:32.099: //2/880B2D000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=200(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0823055942(TON=Unknown, NPI=Unknown))
Feb 10 04:43:32.099: //2/880B2D000000/CCAPI/cc_process_call_setup_ind:
   Event=0x406D1AD0
Feb 10 04:43:32.099: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 0823055942
Feb 10 04:43:32.099: //2/880B2D000000/CCAPI/ccCallSetContext:
   Context=0x30013CE0
   >>>>CCAPI handed cid 2 with tag 100 to app "_ManagedAppProcess_Default"
 --More--         Feb 10 04:43:32.099: //2/880B2D000000/CCAPI/ccCallProceeding:
Feb 10 04:43:32.099: //2/880B2D000000/CCAPI/ccCallDisconnect:
Feb 10 04:43:32.099: //2/880B2D000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 10 Feb 2015 04:43:32 GMT
CSeq: 101 INVITE
Content-Length: 0
 --More--         Sent:
SIP/2.0 404 Not Found
To: <sip:0823055942@192.168.50.1>;tag=4E0D0-1997
CSeq: 101 INVITE
Content-Length: 0
Feb 10 04:43:32.103: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0823055942@192.168.50.1:5060 SIP/2.0
 --More--         Call-ID: 880b2d00-4d918e6b-8-a32a8c0@192.168.50.10
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 10 04:43:32.103: //2/880B2D000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4058B770, Tag=0x0, Call Id=2,
   Call Disconnect Event Sent
Feb 10 04:43:32.103: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 10 04:43:32.103: :cc_free_feature_vsa freeing 2A5112C0
Feb 10 04:43:32.103:  vsacount in free is 0
CUBE#
Content for Community-Ad
FusionCharts will render here
