CUCM_TO_CUBE Trunk Down - Status Reason 2
ciscoMFNAO
Hi all,
We are configuring a new SIP Trunk to our new 2900 router that will be conneting to a our SIP Provider. Topology looks like:  CUCM---SIP TRUNK - CUBE - SIP TRUNK - SIP PROVIDER
Currentely we are stuck trying to get the CUCM trunk up. We follow Cisco Guide and configure the trunk but the trunk is down with the status reason 2. When a call is placed nothing seems to hit the CUBE with debug enabled.
We wonder if there is something else that needs to be configure first in CUBE as the router is new. Please see bellow the configuration made so far to allow the SIP Trunk connection on the CUBE:
PLEASE HELP...if you have any ideias what can cause this status reason 2 or if there is something that may preventy the router to recieve calls from the CUCM TRunk.
Building configuration...
Current configuration : 2578 bytes
! Last configuration change at 16:33:30 UTC Fri Feb 2 2018 by cisco
! NVRAM config last updated at 13:45:24 UTC Fri Feb 2 2018
version 15.1
hostname JPTLDAMAN-RTSIP-01
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 172.29.8.46
  ipv4 0.0.0.0
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
  allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid CISCO2911/K9 sn xxxxxxx
hw-module pvdm 0/0
username xxxxx privilege 15
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description RTACC08-00-G0/9
 ip address 172.29.8.146 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 description SIP To Angola Telecom
 ip address 10.130.2.166 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no mop enabled
interface FastEthernet0/0/0
 no ip address
interface FastEthernet0/0/1
 no ip address
interface FastEthernet0/0/2
 no ip address
interface FastEthernet0/0/3
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.29.8.1
logging trap debugging
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
 exec-timeout 9 0
 privilege level 0
line aux 0
 exec-timeout 9 0
 privilege level 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 --More--          transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 60 0
 privilege level 15
 password cisco
 login local
 transport input all
line vty 5 15
 exec-timeout 9 0
 privilege level 15
 login
 transport input all
scheduler allocate 20000 1000
end
JPTLDAMAN-RTSIP-01#             sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 16:37 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
JPTLDAMAN-RTSIP-01 uptime is 4 hours, 2 minutes
System returned to ROM by reload at 12:29:51 UTC Fri Feb 2 2018
System restarted at 12:31:26 UTC Fri Feb 2 2018
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M5.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ171260PS
4 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        CISCO2911/K9          xxxxxxxxxx
 --More--         Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
JPTLDAMAN-RTSIP-01#
ISSUE SOLVED.
This IOS as a bug https://quickview.cloudapps.cisco.com/quickview/bug/CSCub45303.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvf12692
Just Added Dial.Peers to the Configuration as sugested by another member and reload the router as the bug page guides
19 Replies 19
R0g22
The IP that you have configured for the CUBE on CUCM SIP trunk is it 172.29.8.146 ? Add sip bindings to voice service voip/sip configuration as -
bind all source-interface 172.29.8.146
Test after this. If the status is still showing down, enable "debug ccsip messages" and "debug ccsip non-call" and let it run for a couple of minutes. Collect the logs and attach.
Thanks so much for your quick replay.
I tried your sugestion but it is still showing down and nothing is hiting the CUBE. I also can ping from both sides but trunk is still down
Can you paste a snapshot where you see the trunk down ? Do you have Options Ping enabled on the SIP Profile ?
Yes, I have Ping enabled on SIP Profile. Please note the printscreen bellow attached:
Ok. Enable the following on the CUBE -
debug ccsip message
debug ccsip error
Let them run for a couple of minutes and then send me the logs.
No..still not showing anything from debug.
Really strange. CUCM and CUBE are on the same network so I don´t think Firewall is a issue as well.
What do you see in "show logg" ? Add the outputs for -
show tcp brief all
show udp detail
Show logging also doesn´t show activity. Please note the output attached
That's strange. Your router is not listening for UDP and TCP traffic on 5060. Have you added the SIP binds correctly ?
Can you reload the router and also try changing the outgoing transport to UDP on the SIP security profile if you are using the default non-secure one ?
Are you console ? Add an output for "show ip int br | ex un".
Yes I think I configured the bind. Please note the printscreen.
Yes. Reload the router please and then check the outputs for "show tcp br" and "show udp detail" once the router is up. Also try changing the transport protocol to udp on CUCM sip security profile.
Yes, I reloaded the router and the reason changed to 1. Please check the outputs attached
Have you tried resetting the trunk once ?
If you disable options, do calls hit the CUBE ?
