CUCM to FXS port connected via SIP one way audio path and no ring back tone
regu1
Hi everybody
I have integrated an ISR 4331 with FXS ports connected to CUCM 11.5 via SIP .The issue i am facing is When i make an call from CUCM endpoint to the FXS extension i am not getting ringback tone in CUCM end ,but the FXS extension is ringing and when answered it has one way audio path , When i try to dial from FXS port to an ip phone in CUCM end the call is not getting established .Have attached the Show run output from ISR 4331 ,kindly give your valuable guidance to overcome this issue.
regu1
The ISR 4331 config which has the issue
MCIT-VGW-1#show run
Building configuration...
Current configuration : 5556 bytes
! Last configuration change at 11:06:13 utc Sat Feb 23 2019 by mcitadmin
! NVRAM config last updated at 10:17:02 utc Sat Feb 23 2019 by mcitadmin
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname MCIT-VGW-1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone utc 4 30
subscriber templating
voice call send-alert
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
voice class uri 2 sip
host ipv4:172.14.14.10
host ipv4:172.14.14.13
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g722-64
voice class server-group 1
ipv4 172.14.14.10 preference 1
ipv4 172.14.14.13 preference 2
voice class sip-options-keepalive 1
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FDO223109CZ
diagnostic bootup level minimal
username mcitadmin privilege 15 password 0 Mc!t@k@bul
redundancy
mode none
ip address 172.14.14.20 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface Service-Engine0/1/0
no ip address
interface Service-Engine0/2/0
no ip address
interface Service-Engine0/4/0
no ip address
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 172.14.14.3
control-plane
voice-port 0/1/0
ring frequency 50
ring cadence pattern01
voice-port 0/1/1
ring frequency 50
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1901 pots
destination-pattern 1901
port 0/1/0
dial-peer voice 1902 pots
destination-pattern 1902
port 0/1/1
dial-peer voice 2 voip
description incomming calls from CUCM
session protocol sipv2
incoming uri via 2
voice-class codec 1
dtmf-relay sip-kpml rtp-nte
no vad
dial-peer voice 1801 voip
description outgoing calls to CUCM
destination-pattern 1801
session server-group 1
voice-class codec 1
no vad
line con 0
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password Mc!t@k@bul
login local
transport input all
ntp server 172.12.12.21
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
MCIT-VGW-1#show version
Cisco IOS XE Software, Version 16.06.03
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.3, RELEASE SOFTWARE (fc8)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Feb-18 23:54 by mcpre
ROM: IOS-XE ROMMON
MCIT-VGW-1 uptime is 2 days, 19 hours, 3 minutes
Uptime for this control processor is 2 days, 19 hours, 6 minutes
System returned to ROM by Reload Command
System restarted at 16:43:56 utc Wed Feb 20 2019
System image file is "bootflash:isr4300-universalk9.16.06.03.SPA.bin"
Last reload reason: Reload Command
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
--More--   Current Type Next reboot
appxk9 None None None
uck9 uck9 Permanent uck9
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1796073K/6147K bytes of memory.
Processor board ID FDO2232A2FP
3 Gigabit Ethernet interfaces
8 Voice FXS interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
