07-06-2012 05:17 PM - edited 03-16-2019 12:04 PM
I have an interesting case where the RightFax server is not seeing any ANI/DNIS information coming from CUCM. The steup is pretty standard: PSTN ---> MGCP Controlled GW ----> CUCM ---> Route Pattern ----> SIP Trunk ----> RightFax Server.
RightFax does not support NSE, so I made sure it was a T38 passthrough setup in the MGCP code.
All the faxes are supposed to be routed to individuals within RightFax, however it's all just dumping to the default administrator account. RightFax support says that's because CUCM is not passing the digits over. However you can see the information in the debugs. Just not where RightFax wants them.
Any ideas?
Solved! Go to Solution.
07-12-2012 03:07 PM
Chris,
Looking at the traces we can 1000% confirm that cucm is sending the rights digit and looking also at the trace from the brookout server, we see the did_digits=980 (called number) and the ANI=5034062124
+++CUCM sends an Invite to DN=980 @ip=192.9.201.19+++++++
07/12/2012 10:56:04.406 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 192.9.201.19:[5060]:
INVITE sip:980@192.9.201.19:5060 SIP/2.0
Date: Thu, 12 Jul 2012 17:56:04 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <5034062124>;tag=889d6a73-ead2-4dbe-880d-1e50bab4ebeb-207029435034062124>
+++CUCM receives a ringing from the brookout server+++
07/12/2012 10:56:04.409 CCM|//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 426 from 192.9.201.19:[5060]:
SIP/2.0 180 Ringing
To: <980>;tag=8bd3590-0-13c4-55013-41134-5e021916-41134980>
Call-ID:
d7e49780-fff10fb4-dc-bc80ac0@192.10.200.11
+++++CUCM receives a 200 ok from the dialogic server with SDP+++++++
incoming SIP UDP message size 709 from 192.9.201.19:[5060]:
SIP/2.0 200 OK
Call-ID: d7e49780-fff10fb4-dc-bc80ac0@192.10.200.11
CSeq: 101 INVITE
Via: SIP/2.0/UDP 192.10.200.11:5060;branch=z9hG4bK42a6b3da3c3
Supported: timer
User-Agent: Brktsip/6.3.4B11 (Dialogic)
Contact: <192.9.201.19>
Session-Expires: 1800;refresher=uas
Content-Type: application/sdp
Content-Length: 218192.9.201.19>980>5034062124>
v=0
o=- 2209261406 0736283000 IN IP4 192.9.201.19
s=no_session_name
t=0 0
m=audio 56224 RTP/AVP 0
c=IN IP4 192.9.201.19
a=rtpmap:0 pcmu/8000
m=audio 56224 RTP/AVP 8
a=rtpmap:8 pcma/8000
+++++CUCM sends an ACK to the 200 ok with the codec to use for the call as g711ulaw+++++
07/12/2012 10:56:04.458 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 192.9.201.19:[5060]:
ACK sip:192.9.201.19:5060 SIP/2.0
Allow-Events: presence
Content-Length: 178
Via: SIP/2.0/UDP 192.10.200.11:5060;branch=z9hG4bK42b7ac2dab8
CSeq: 101 ACK
Max-Forwards: 70980>5034062124>
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 192.10.200.11
s=SIP Call
c=IN IP4 192.10.200.2
t=0 0
m=audio 17522 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
m=audio 0 RTP/AVP 8
++++After the call was established, cucm gets an invite from the brook rout server to swicth to fax using t.38+++++++++
NB: The calling and called number is correct or present.
07/12/2012 10:56:07.462 CCM|//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 815 from 192.9.201.19:[5060]:
INVITE sip:5034062124@192.10.200.11:5060 SIP/2.0
From: <980>;tag=8bd3590-0-13c4-55013-41134-5e021916-41134
To: <5034062124>;tag=889d6a73-ead2-4dbe-880d-1e50bab4ebeb-20702943
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.9.201.19:5060;branch=z9hG4bK-41137-fe34258-4246a3f0
Supported: timer
Max-Forwards: 70
Min-SE: 1800
Content-Length: 286192.9.201.19>5034062124>980>
v=0
o=- 2209261406 0789715000 IN IP4 192.9.201.19
s=no_session_name
t=0 0
m=image 56224 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:72
a=T38FaxUdpEC:t38UDPRedundancy
++++after cucm sent a trying to this invite, cucm sends a 200 ok with t.38 capabilites++++++++
SIP/2.0 200 OK
Date: Thu, 12 Jul 2012 17:56:07 GMT
P-Asserted-Identity: "TRUECOMM COM" <5034062124>
Supported: replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Remote-Party-ID: "TRUECOMM COM" <5034062124>;party=called;screen=yes;privacy=off
Content-Length: 144
Contact: <5034062124>
CSeq: 1 INVITE5034062124>5034062124>5034062124>5034062124>980>
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 192.10.200.11
s=SIP Call
t=0 0
m=image 17522 udptl t38
m=audio 0 RTP/AVP 8
++++++next we see the dialogic sending an ACK to the 200 ok+++++++
Incoming SIP UDP message size 458 from 192.9.201.19:[5060]:
ACK sip:5034062124@192.10.200.11:5060 SIP/2.0
From: <980>;tag=8bd3590-0-13c4-55013-41134-5e021916-41134980>
To: <5034062124>;tag=889d6a73-ead2-4dbe-880d-1e50bab4ebeb-207029435034062124>
Call-ID:
CSeq: 1 ACK
Via: SIP/2.0/UDP 192.9.201.19:5060;branch=z9hG4bK-41137-fe34262-1a8a2c82
Contact: <192.9.201.19>192.9.201.19>
Max-Forwards: 70
Content-Length: 0 Incoming SIP UDP message size 458 from 192.9.201.19:[5060]:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0192.9.201.19>5034062124>980>
So at this point I believe we can safely conclude that this is not a case of cucm not sending the called number.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-10-2012 02:13 PM
PSTN Router Model, Router IOS Version, and PVDM-2 or PVDM-3?
07-11-2012 04:03 PM
Afternoon Shane,
I'm still banging my head on this, I'm looking at debug statements that show the DNIS/ANI leaving CUCM. When they get to RightFax, their debugs show no information. So of course the error falls back to my setup...somewhere.
PSTN Router Model: 3825
IOS: 12.4(20)T1
PVDM2 version with 23.6.2 firmware
Current MGCP Stat:
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: CUCMPUB Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough disabled
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp DISABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: cs3
MGCP default package: fxr-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
hs-package atm-package ms-package dt-package mo-package
res-package mt-package fxr-package md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is ENABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is ENABLED: 000000
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bound to interface GigabitEthernet0/0
MGCP media bound to interface GigabitEthernet0/0
MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Dynamic payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP Guaranteed scheduler time is DISABLED
MGCP DNS stale threshold is 30 seconds
Current SIP Profile config on SIP:
Early offer for G.Clear Calls: Disabled
Checkmark on Outgoing t.38 invite include audio mline
SIP Security Profile:
Incoming TCP+UDP
Outgoing UDP --- This was set because RightFax only accepts UDP
Trunk config:
Port: 5060
DTMF: RFC 2833
Route Pattern:
4.9XX with discard predot.
Called Party selection has been: Cisco CM, Subscriber, National, and Unknown with no changes in DNIS/ANI presentation to RightFax.
07-11-2012 07:44 PM
I dont know why rightfax does this, but this is the second time I am seeing this issue on the forum. You need to look at cucm traces and see what CUCM is sending to rightfax over the sip trunk. Can you enable detailed cucm traces and attach here? Please send the calling and called number
07-11-2012 08:06 PM
Chris, are you opposed to trying H323 instead of SIP from CUCM to RFax?
07-12-2012 11:32 AM
Not opposed, would like to avoid that until I give up or this wall I'm banging my head on does. =)
I've attached a CUCM trace log. Fire up VLT and parse out for 980 or and IP ending in .19 That would be the RightFax Server.
Here is something odd though, looking at the output of the RightFax system, they seem to be parsing on Calling instead of Called....at least that's how I'm reading this output below:
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BfvCallWaitForSetup returns=1
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BoACALL:Call type=4 did_digits='980'
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BoACALL:CDPN:980, CDPSA:, CIPN:5034062124, CIPSA:, RN:, RR:0
(M-D-Y)07-09-2012 09:08:59[PID:113316332,TID:113316332]<->CH[0] Brooktrout: BoPANI:Parsing ANI/DNIS String "5034062124" using pattern "49XX"
(M-D-Y)07-09-2012 09:08:59[PID:113316332,TID:0]<->CH[0] Brooktrout: BoPANI:Returning (0), ANI="", DNIS=""
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BoACALL:dest_id='', rtenum=, len=0
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BoACALL(CallAccept): call_result.status = 0, call_result.line_status:0, Line_state=1
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BoACALL(WaitForAccept): call_result.status = 0, call_result.line_status:0, Line_state=2
(M-D-Y)07-09-2012 09:08:59[PID:118152460,TID:113316332]<->CH[0] Brooktrout: BfvCallWaitForAccept = AnswerSuccess
07-12-2012 03:07 PM
Chris,
SIP/2.0 180 Ringing
Call-ID:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: timer
v=0
s=no_session_name
t=0 0
Content-Length: 178
CSeq: 101 ACK
v=0
s=SIP Call
t=0 0
a=ptime:20
m=audio 0 RTP/AVP 8
CSeq: 1 INVITE
Supported: timer
Max-Forwards: 70
Min-SE: 1800
v=0
s=no_session_name
t=0 0
a=T38FaxVersion:0
SIP/2.0 200 OK
Supported: replaces
Content-Length: 144
v=0
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 8
Call-ID:
CSeq: 1 ACK
Max-Forwards: 70
CSeq: 1 ACK
Max-Forwards: 70
07-12-2012 03:53 PM
Thank you very much for the step through. That helps with disecting the SIP information.
The RightFax vendor is still questioning why on his debug the ANI/DNIS values output are blank. My only response was, "That sounds like a Layer 7 issue." It was a joke, but as you pointed out in the CUCM debugs, we have passed along the ball to the next player and it's up to them to get it in the goal.
To rule out bugs on the RightFax side, the vendor is requesting an upgrade of the RightFax server to their latest SR3 version.
Thanks again for your help and I'll keep you posted.
