CUCM Trunk sip to isp provider without CUBE
I try to configure a trunk sip with a provider without cube.
I can to make outgoing call without problem, it work fine!
But when i initiate a incoming call, my CUCM return the SIP message "404 Not found".
In my trunk sip configuration, in the inbound call section, i have apply a CSS who can access to a translation pattern:
- i receive from the provider 214097015@xyz.com
- the created translation pattern 214097015, his affect CSS can access internal phone, translate to the phone 1022 (called transf. pattern).
- actually the significant digit for the inbound call of the trunk sip is "all" (but i have test with 10, 9, 4 receive digit and modified the translation pattern, digit but same problem).
I don't understand why the cum return the SIP msg 404.
Somebody have a idéa?
Misconfiguered translation pattern? (i don't but think this, but...)
Thank a lot.
17 Replies 17
Dennis Mink
Giles,
can you diagnose by elimination, i.e. can you assign the extension 2140970 to a phone without the translation pattern. This way you can potentially narrow it down to your Translation pattern.
cheers
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
I have also test this but no succes...
Can you send us cucm logs. Please include calling and called number
Please rate all useful posts
Hi Ayodeji,
My external calling number ar 0290035006 or 0296622525.
My called number is 214097015 (same as the phone's DN).
From CUCM browse to DNA. Then try to apply the called number as received from ITSP and see what is happening to the call. Please share the DNA report for us to look as well
hi, no problem with DNA.
I'm not 100% sure but in your provided traces, I saw the following:
Incoming Invite from your SIP Provider:
02/02/2016 13:52:26.516 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 1129 from 185.48.253.8:[5060]:
[352051,NET]
INVITE sip:214097015@93.17.11.122:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 185.48.253.8:5060;branch=z9hG4bK+c8bbbe2e413a008dbde8790cf66cf5841+sip+1+aa5b21bb
From: <sip:0290035006@pbx.eqinoxe.com>;tag=185.48.253.8+1+8c92233+8324d05c
To: <sip:214097015@pbx.eqinoxe.com>
CSeq: 366469310 INVITE
Expires: 180
Content-Length: 213
Call-Info: <sip:185.48.253.8:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: resource-priority, 100rel
Contact: <sip:1df0c46eae92fcedc3325985866fe936@185.48.253.8:5060>
Content-Type: application/sdp
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event, calling-name
Call-ID: 0gQAAC8WAAACBAAALxYAABZYlz4DcFoS784OuCH734vse0Fj7FmITe7BpycOxreV@185.48.253.8
Organization: Metaswitch Networks
Max-Forwards: 65
P-Asserted-Identity: <sip:0290035006@pbx.eqinoxe.com>
Accept: application/sdp, application/dtmf-relay
v=0
o=- 137749983028104 137749983028104 IN IP4 185.48.253.8
s=-
c=IN IP4 185.48.253.8
t=0 0
m=audio 44328 RTP/AVP 0 8 2 18 101
a=sendrecv
a=rtpmap:101 telephone-event/8000
a=fmtp:18 annexb=no
a=ptime:20
Source Filename: ccm00000011.txt.gz
02/02/2016 13:52:26.519 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 185.48.253.8:[5060]:
[352053,NET]
SIP/2.0 404 Not Found
To: <sip:214097015@pbx.eqinoxe.com>;tag=205181~266b517d-ba24-4bf3-8795-bef832f0ce59-26994370
Date: Tue, 02 Feb 2016 12:52:26 GMT
Allow-Events: presence
Reason: Q.850;cause=1
Content-Length: 0
I think the "TO" Field is wrong adress. There should be the the IP adress from the cucm instead of the domain "pbx.eqinoxe.com". It have to like like To: <sip:214097015@192.168.100.205> (If this is your CUCM)
Hi Gilles,
Please uncheck MTP required option,reset the trunk, make another call and attach the same ccm trace.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi also tested without MTP, but i have attached the new trace without MTP
Hi Gilles,
Can you please post a screenshot of cucm trunk configuration?
thanks
Carlo
Hi Carlo, you can seen my trunk sip configuration in the attachment file.
Thanks.
Thanks Gilles for the attachment.
From you screenshot I see that you created a sip profile.
Which value did you modify on that profile?
Please Let me know and, (sorry to bother you) attach a screenshot of that profile.
Carlo
i have test with the default value of the standard sip profil and i a have test with another profil (attach file)
Hi Gilles,
is CUCM able to resolve names?
Please as destination address on sip trunk configuration, add pbx.eqinoxe.com instead of the ip address.
Here what we can find in the invite message from your provider.
Via: SIP/2.0/UDP 185.48.253.8:5060;branch=z9hG4bK+b6489d1a817bb0876ee517a49c4635eb1+sip+1+aa4f1162
From:<sip:0290035006@pbx.eqinoxe.com>;tag=185.48.253.8+1+946e09+9d0bd2a6
Please try it and let me know
Carlo
