Beginner
CUCM Unattended Installation
Can someone tell me the steps for CUCM Unattended installation
So the scenario is
1. Using the VSchere API i will be importing/creating a new machine using the standard Cisco OVA template
2. I will point the CD to the .iso of CUCM
3. I will create a virtual floppy disck containing the platformconfig.xml
4. Will start the VM and make the VM boot from CD
5. Now in manual mode the CUCM asks for various questions like IP Address, Host Name, Admin Passwords, etc. So using the API method/automatic provisioning i will not be able to do so. hence need a solution to do unattended installation of CUCM.
If someone has any suggestion or has a pdf or steps how to achieve this, please help me
1 REPLY 1
Highlighted
Participant
Online Answer File generator is located at http://www.cisco.com/web/cuc_afg/index.html
Depending on your server, you might have to create a virtual floppy for the platformConfig.xml file (the answer file)
Content for Community-Ad
FusionCharts will render here
