CUCM Upgrade 10.5 to CUCM 11.5 failed
Remon Adel
Dear All ,
when we upgrade our CUCM 10.5 to CUCM11.5 (standard Upgrade) this error  appeared to us .
Current Version     10.5.2.10000-5
Upgrade Version     11.5.1.13900-52
09/29/2017 12:35:49 upgrade_install.sh|Removing /common/rpm-archive/11.5.1.13900-52|<LVL::Info>
09/29/2017 12:35:50 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:604, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
09/29/2017 12:35:50 upgrade_install.sh|Parse argument status=upgrade.stage.error|<LVL::Debug>
09/29/2017 12:35:50 upgrade_install.sh|_set_upgrade_status_attribute: status set to upgrade.stage.error|<LVL::Debug>
09/29/2017 12:35:50 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
09/29/2017 12:35:50 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 11450).|<LVL::Debug>
09/29/2017 12:35:50 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 11450)|<LVL::Debug>
acampbell
Hi Remon,
From the release notes:-
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/SU3/cucm_b_release-notes-cucm-imp-1151su3/cucm_b_release-notes-cucm-imp-1151su3_chapter_01.pdf
Looks to me like you are hitting the "Restrictions" table
Upgrade Path Restrictions for Release 11.5(x)
Upgrade and migration paths generally support the Service Updates (SU) within each path; however, there
are some exceptions for specific SU releases. The table below lists the exceptions for upgrades and migrations
to Cisco Unified Communications Manager Release 11.5(x).
Table 5: Restrictions to Supported Upgrade and Migration Paths, Cisco Unified Communications Manager Release 11.5(x)
From To Description
Path is unsupported. For these
releases, upgrade to 11.5(1)SU2
instead.
Regards, Alex. Please rate useful posts.
I already did that and get success (Upgrade to 11.5(1)SU2 ) not SU3,Thanks
usantra
