05-18-2017 04:26 AM - edited 03-17-2019 10:21 AM
want to upgrade a CUCM 11.5.1 (SU1) to SU2. The upgrade failed wih this message:
Its an vm machine on ESXi 6.0.0
A IMP server is configured on CUCM. This server already have the SU2 version.(fresh install)
Somebody knows what could be wrong?
Solved! Go to Solution.
05-18-2017 05:01 AM
Sounds like the below BUG.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva26416/?reffering_site=dumpcr
05-18-2017 04:32 AM
can you attach the complete logs in a .txt file.
JB
05-18-2017 04:35 AM
05-18-2017 05:01 AM
05-18-2017 06:24 AM
That was the right hint. Upgrade now running after deleting the templates.
05-18-2017 06:31 AM
It was not a hint :-), i knew that was the issue
below is what i saw in your logs that pointed me to that BUG.
05/18/2017 13:20:46 component_install|(CAPTURE) /var/log/active/cm/trace/dbl/sdi/CheckAndCreateDefaultTemplates.sql.log: 100: ISAM error: duplicate value for a record with unique key.|<LVL::Debug>
05/18/2017 13:20:46 component_install|(CAPTURE) /var/log/active/cm/trace/dbl/sdi/CheckAndCreateDefaultTemplates.sql.log:Error in line 101|<LVL::Debug>
(Rate if it helps)
JB
05-18-2017 10:30 PM
thank very much fo your quick help. upgrade is successfully ended.
05-18-2017 10:32 PM
Happy to help,
Thanks for updating the post.
JB
10-16-2018 09:09 PM
Thanks a lot Jitender. Your finding helped me to overcome issue of upgrading from 11.5SU2 to SU4. It was right on the mark.
Kudos to Jitender!
01-07-2019 10:34 AM
how can i delete the templates
I am facing the same problem while upgrading to CUCM 12 but mandatory that one template is existing to be assigned to cucm @Jitender Bhandari @Support Albakom
12-29-2021 03:06 AM
i am facing the problem upgrade cuc11.5 to 12.5, please advice and suggested. full log share in attachment.
12/29/2021 16:08:11 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:604, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
10-19-2023 02:07 PM
I had this error during a new installation of versions 12.5 and 14.0. Everything was resolved by increasing the virtual disk size from 80 GB to 110 GB.
