CUCM upgrade fail from 9.1(1) to 9.1(1a)
ts.nakayama
Beginner
Beginner
I tried to upgrade CUCM from 9.1(1) to 9.1(1a) on GUI OS administration.
But, the upgrade process was failed with the following message.
      Invalid Upgrades
      Option Names
          UCSInstall_UCOS_9.1.1.20000-5.sgn.iso
      Status
           The "to" version rules on the active partition intentionally block an upgrade to the version obtained from the name.
Running software version is as follows.
      Partition Versions
           Active Version     9.1.1.11005-1
           Inactive Version     9.1.1.10000-11
      Installed Software Options
           cm-locale-ja_JP-9.1.1.1000-1.cop     Active
           cmterm-iphone-install-130129.cop     Active
           cmterm-android_9.1.1v1.cop     Active
           elm-locale-ja_JP-9.1.1.1000-1.cop     Active
           cmterm-jabbertablet-100v10-dm.cop     Active
           cm-locale-combined_network-9.1.1.1000-1.cop     Active
           cm-locale-ja_JP-9.1.1.1000-1.cop     Inactive
           elm-locale-ja_JP-9.1.1.1000-1.cop     Inactive
           cm-locale-combined_network-9.1.1.1000-1.cop     Inactive
Is there any problem with the update file(UCSInstall_UCOS_9.1.1.20000-5.sgn.iso)?
Aman Soi
Advisor
Advisor
Hi ,
You are trying to upgrade from 9.1.1.10000-11 to 9.1.1.20000-5.You need to have 9.1.1.10000-11 in the  active partition to upload 9.1.1.200000-5.
But I could not find the version 9.1.1.11005-1  in compatibility guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
Aman Soi
Advisor
Advisor
Hi ,
regds,
aman
Hi, aman
Thank you for reply.
I understand the version compatiblity of CUCM upgrade rule.
As you say, 9.1(1a) can not directly upgrade from 9.1(1)ES.
I try to get any ES version of 9.1(1a) from TAC, or wait for the next release.
Tsuyoshi
Please rate the post and mark it as answered.
thanks.
aman
Recognize Your Peers
