03-11-2013 06:54 AM - edited 03-16-2019 04:11 PM
I tried to upgrade CUCM from 9.1(1) to 9.1(1a) on GUI OS administration.
But, the upgrade process was failed with the following message.
Invalid Upgrades
Option Names
UCSInstall_UCOS_9.1.1.20000-5.sgn.iso
Status
The "to" version rules on the active partition intentionally block an upgrade to the version obtained from the name.
Partition Versions
Active Version 9.1.1.11005-1
Inactive Version 9.1.1.10000-11
Installed Software Options
cm-locale-ja_JP-9.1.1.1000-1.cop Active
cmterm-iphone-install-130129.cop Active
cmterm-android_9.1.1v1.cop Active
elm-locale-ja_JP-9.1.1.1000-1.cop Active
cmterm-jabbertablet-100v10-dm.cop Active
cm-locale-combined_network-9.1.1.1000-1.cop Active
cm-locale-ja_JP-9.1.1.1000-1.cop Inactiveelm-locale-ja_JP-9.1.1.1000-1.cop Inactive
cm-locale-combined_network-9.1.1.1000-1.cop Inactive
Is there any problem with the update file(UCSInstall_UCOS_9.1.1.20000-5.sgn.iso)?
Solved! Go to Solution.
03-11-2013 07:56 AM
Hi ,
You are trying to upgrade from 9.1.1.10000-11 to 9.1.1.20000-5.You need to have 9.1.1.10000-11 in the active partition to upload 9.1.1.200000-5.
But I could not find the version 9.1.1.11005-1 in compatibility guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
regds,
aman
03-11-2013 07:56 AM
Hi ,
regds,
aman
