CUCM upgrade from 7.0 to 8.0(3)
rajesh.kumar
Level 4
Level 4
I am planning for Upgrade CUCM 7.0 to 8.0(3).
Does anyone has upgradation documentation for CUCM from 7.0 to 8.0 upgrade?
I am not able to find it out in Cisco site.
Present version 7.0 is running on MCS-7835. It is NOT on VM.
Upgradation to version 8.0, Is there any VM ESX required in this upgradation?
Any precaution required on installation/licensing part during upgradation from 7.0 to 8.0?
Is it same as upgradation from 6.x to 7.x or different?
Waiting for suggestion.
Rgds
Rajesh
6 Replies 6
Jaime Valencia
All the information is in the documentation section, from www.cisco.com -> Support -> Install & Upgrade.
There are plenty of requirements for the virtualization option and you need to meet all of them for it to be supported
Installing Cisco Unified Communications Manager on Virtualized Servers
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/virtual/servers.html
Software Upgrades
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cucos/8_0_1/cucos/iptpch7.html
Table 6     Supported Cisco Unified Communications Manager Upgrades for Release 8.0(2c)SU1 through 8.0(x)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp286194
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Is virtualization is MUST while upgrading CUCM from 7.0 to 8.0(3) ??
Rgds
Rajesh
No; VMware-based virtualization is not required, only an option.
Hi Jonathan Schulenberg
Thanks a lot, pls. clarify this,
Only on UCS hardware we have option of virtualization for CUCM 8.x onwards.
For upgrdation on MCS-7835 from 7.x to 8.x no need of virtualization and normal upgradation, correct?
Upgradation procedure is like, insert upgradation DVD and proceed with upgradation what we used to do it for 6.x to 7.x, correct?
thanks
Hello Rajesh,
As per: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
Table 6 states that if you want to upgrade to 8.0.3.10000.8 you can do a direct upgrade from the following 7.x versions:
7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a,  7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a)SU1, 7.1(2a),  7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 7.0(1)SU1a,  7.0(1)SU1, 7.0(1)
Hope this helps,
John
One question:
Upgrade DVD I received from Cisco mentioned "Bootable and Upgrade DVD from 7.x to 8.x"
Usually there will be ISO file ex:UCSInstall_UCOS_X.X.X.X.X.sgn.iso for upgradation.
But I don't see those ISO files in this DVD. Is it right DVD for upgrade from 7.x to 8.x?
Which file from this DVD, CUCM uses for upgrade from 7.x to 8.x?
Here I have attached the screenshot of the DVD files.
Pls. advice.
Rajesh
