12-26-2010 04:03 AM - edited 03-16-2019 02:35 AM
I am planning for Upgrade CUCM 7.0 to 8.0(3).
Does anyone has upgradation documentation for CUCM from 7.0 to 8.0 upgrade?
I am not able to find it out in Cisco site.
Present version 7.0 is running on MCS-7835. It is NOT on VM.
Upgradation to version 8.0, Is there any VM ESX required in this upgradation?
Any precaution required on installation/licensing part during upgradation from 7.0 to 8.0?
Is it same as upgradation from 6.x to 7.x or different?
Waiting for suggestion.
Rgds
Rajesh
12-26-2010 08:48 PM
All the information is in the documentation section, from www.cisco.com -> Support -> Install & Upgrade.
There are plenty of requirements for the virtualization option and you need to meet all of them for it to be supported
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/virtual/servers.html
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cucos/8_0_1/cucos/iptpch7.html
Table 6 Supported Cisco Unified Communications Manager Upgrades for Release 8.0(2c)SU1 through 8.0(x)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp286194
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-27-2010 07:03 AM
Is virtualization is MUST while upgrading CUCM from 7.0 to 8.0(3) ??
Rgds
Rajesh
12-27-2010 10:07 AM
No; VMware-based virtualization is not required, only an option.
12-27-2010 11:46 AM
01-10-2011 02:36 AM
Hello Rajesh,
As per: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
Table 6 states that if you want to upgrade to 8.0.3.10000.8 you can do a direct upgrade from the following 7.x versions:
7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a)SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 7.0(1)SU1a, 7.0(1)SU1, 7.0(1)
Hope this helps,
John
01-18-2011 12:35 PM
One question:
Upgrade DVD I received from Cisco mentioned "Bootable and Upgrade DVD from 7.x to 8.x"
Usually there will be ISO file ex:UCSInstall_UCOS_X.X.X.X.X.sgn.iso for upgradation.
But I don't see those ISO files in this DVD. Is it right DVD for upgrade from 7.x to 8.x?
Which file from this DVD, CUCM uses for upgrade from 7.x to 8.x?
Here I have attached the screenshot of the DVD files.
Pls. advice.
Rajesh
