04-05-2016 07:56 AM - edited 03-17-2019 06:28 AM
I have a customer who has recently upgraded to CUCM ver 11.0.1 and has raised a query over the excessive time taken for users to logon to the Extension Mobility service - he says it takes about 45 seconds.
I have removed all reliance on DNS, restarted the servers but still getting the same time. Are there any known issues with 11.0 with Ext Mob?
They are not going properly live for another week so we have time for upgrades. Would you recommend running a full production environment with 11.0?
Many thanks, John.
Solved! Go to Solution.
04-05-2016 10:01 AM
Since you have not mentioned the phone models you are using there, hence I am assuming that the phone models facing this issue is 7900 series. As CM version 11 upgrades the FW version to 9.4(2) SR1 for most of the phone models including 7900 series, the below defect comes into effect. Contact TAC and ask for the ES that will resolve the issue in case you want to use the same FW version i.e. 9.4(2) SR1, or try downgrading the FW
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv11036/?reffering_site=dumpcr
Link to CM 11 Release Notes providing information on the FW versions:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_0_1/CUCM_BK_R30921A8_00_CUCM_release-notes_1101/CUCM_BK_R30921A8_00_CUCM_release-notes_1101_chapter_0110.html#CUIP_RF_P0DD32F5_00
Deepak
04-05-2016 11:04 AM
Hi John,
EM service is based on HTTS request and response.
I would do the following to resolve this:
> restart the EM service and check if the issue resolved
> If we have done above, collect the packet capture from the phone and the cucm server providing the EM service -----> to check the communication between the server and the phone.
> If we have done the above, collect the EM service logs for a test login ---> to find out if the service itself is not behaving correctly.
Please upload the logs/captures for a test login to check further if still not resolved.
~Amit
Please rate if helpful
04-05-2016 08:07 AM
Is there any 3rd party integration with cucm, Which sends HTTP request to cucm ?
Suresh
04-06-2016 06:51 AM
Hi Suresh,
many thanks for your reply.
There are no 3rd party integrations that I know of.
The customer has used their support to open a TAC case so we can leave this one now.
Thanks anyway.
04-05-2016 08:09 AM
Exactly what do you mean by a "full production environment"??
Are you not running a fully supported environment as it is???
04-06-2016 06:49 AM
Hi Jamie, yes they have full software support - I just meant that they are not due to go live just yet.
04-05-2016 10:01 AM
Deepak
04-05-2016 11:04 AM
Hi John,
~Amit
04-06-2016 06:54 AM
Hi Amit,
many thanks for your reply - much appreciated.
I was about to capture packets using WireShark but this has been passed to Cisco TAC at the customers insistence.
04-06-2016 06:56 AM
Hi Deepak,
thanks very much for your reply - very much appreciated.
This is now with Cisco TAC at the customers request.
Thanks anyway - useful information in the links provided.
04-06-2016 08:23 AM
No isses John, since it is with TAC now I am sure the issue will get resolved. I am pretty confident that it will/should be an issue with the FW version but whatever it comes to be, do not forget to update the thread so that it can help other customers out there as well.
Deepak
