04-04-2013 03:02 AM - edited 03-16-2019 04:36 PM
Dears,
Now i am instalting cucm cluster v8.6.2.
i installed the publisher and hostname CUCM-Pub the i changed the hostname in GUi to the cucm ip addressn(10.10.10.10).
now i am installing the subscriber and asked me about the first node
Hostname: CUCM-Pub
Ip : 10.10.10.10
sec password: .......
then subscriber check the publisher but it cant see the publisher.
Please advise ASAP.
BR,
Haytham
Solved! Go to Solution.
04-04-2013 04:57 AM
Hi ,
From the snapshot, it seems that there is a version mismatch .
ON PUb, CUCM version is 8.6.2.20000-2 .Please provide for SUB.
regds,
aman
04-04-2013 03:10 AM
HI
Please restart the Publisher server after hostname change.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
04-04-2013 03:15 AM
Dear Ronak
thanks for your support.
I restarted the pulisher but the same issue.
i need to add note:
i add the dns and domain name during the installation of pub and sub.
but the domain name and domain ip now down (we didnt implement the domain yet).
this can affect the validation betwwen the pub and sub during the installation or not.
Please advise.
BR,
haytham
04-04-2013 03:30 AM
If your DNS is down and u are adding, the installation won't succeed.
Server would look for DNS/NTP servers. They should be reachable.
Please refer the link for Change of hostname in Publisher.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/ipchange/ipchg802.html
regds,
aman
04-04-2013 03:14 AM
add the subscriber to the publisher to solve this issue
Anas
please don't forget to rate the helpful posts
04-04-2013 03:17 AM
Hi anas,
I add the sub on the pub with the ip address of the sub.
but the same problem.
04-04-2013 03:30 AM
Dears
it gave me the following error
configure version 8.6 dosn't match the version at 10.10.10.10 (Publisher ip address)
the publisher was 8.5 then i upgraded it 8.6.2 then i make a fresh installation to the sub with the same media (8.6.2)
any advise
04-04-2013 03:35 AM
Hi ,
What u saying is that u had Call Manager version 8.5 which was having hostname CUCM-PUb? You upgraded CUCM to 8.6.2 .Did u restore the backup on Pub?
Now u are trying to add new subscriber on version 8.6.2 Is it so?
regds,
aman
04-04-2013 03:38 AM
Hi Aman
Yes i restored the backup on pub
yes i'm
04-04-2013 03:37 AM
what is your active partition, is it 8.6.2 or 8.5 ? the active partition should be 8.6.2
Anas
04-04-2013 03:40 AM
Hi anas
it's 8.6.2
now i can access the pub GUI and the version is 8.6
04-04-2013 03:49 AM
Hi ,
As u have said that DNS servers are not configured in setup.This means earlier DNS was working because PUB was working and the installation of PUB got completed.
Can u remove DNS entries from the PUB and then,try adding SUB in PUB?
use command to make primary and secondary dns server as 0.0.0.0
set network dns primary 0.0.0.0
set network dns secondary 0.0.0.0
regds,
aman
04-04-2013 03:52 AM
Hi aman
If i changed the DNS the lic will be invalid
04-04-2013 03:55 AM
Are u using LICENSE MAC?
Can't u make the DNS server reachable?
regds,
aman
04-04-2013 03:59 AM
Hi Aman
Yes
Mac Lic
