07-10-2018 09:56 AM - edited 03-17-2019 01:10 PM
Hi All,
I intend to create MoH for an remote office (main office already has MoH), here I am experiencing a question- what is logic to select audio source?
- if on phone device page, put 'none' in User Hold MOH Audio Source, then it should go check Device Pool (MRGL), is it correct?
- MRGL in Device Pool has MRG-> MOH_4, then how this music on hold server select which audio source? there are 3 audio sources in Media Resources-> music onhold audio sources.
thank.s
07-10-2018 10:12 AM
07-10-2018 10:21 AM
thanks Nipun,
in my production, line\device level it does select 'none', and holdee is able to get music, I guess there is a clusterwise default setup somewhere to pick up a audio sources.
and I got 3 audio sources there, only third sources is selected every time if put none on phone line\device level. these 3 sources has any priority?
thanks again.
07-10-2018 10:33 AM
07-10-2018 10:53 AM
Cisco Unified Communications Manager implements four levels of prioritized audio source ID selection with level four as highest priority and level one as lowest priority.
–The system selects audio source IDs at level four, which is directory/line-based, if defined. (Devices with no line definition, such as gateways, do not have this level.)
–If no audio source ID is defined in level four, the system searches any selected audio source IDs in level three, which is device based.
–If no level four nor level three audio source IDs are selected, the system selects audio source IDs that are defined in level two, which is Common Device Configuration-based.
–If all higher levels have no audio source IDs selected, the system searches level one for audio source IDs, which are clusterwide parameters.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsmoh.html
It also explains the MRG selection, might want to read through the whole link
