CUCM v11.5 Critical Error | The installation has encountered a unrecoverable internal error
Not applicable
Hello everyone,
I'm trying to install the CallManager SUB v11.5 over WAN in the DR site and facing below error, is there anyone have an idea how to solve this issues.
15 Replies 15
Jaime Valencia
By any chance does any of the passwords in that cluster contain (), [] or {}???
If they do, change the password and avoid those characters.
I'm assuming the CoW network requirements are met and that those are not an issue.
java
if this helps, please rate
By any chance does any of the passwords in that cluster contain (), [] or {}??? YES for the LDAP integration
but do you think this will affect the installation of the SUB ??
Hi Moawia,
Can you attach the complete logs to .txt file to this thread.
JB
Hi Jitender,
is there any way to get that log file
You need to configure serial port on VM for this, below is the link which you can refer for this.
https://supportforums.cisco.com/document/11936186/dumping-cucm-fresh-install-logs-virtualization
Suresh
Hello All
The problem has been resolved after contact Cisco TAC we found that DB user account password didn't match the application password this cos the installation issue i face
Thank you all for assistance
Hi!
Can you please elaborate on the DB User Account - which user it is (OS ?) ?
I am getting the same error, while i am trying to add a subscriber to a CUCM 11.5.
Thanks!
Shachar
attached, the log.
thanks,
This is not the actual logs.., did you get chance to open it to read ? Seems you have not followed the procedure properly.
Suresh
No special characters for the security password, or any other platform user? or any of the built-in users?
java
No
Just want to add a point
If you are using Private IP to install it, just ping it once to make sure no one is using it in your network so if it Request timed out then only you can use it
Yousifalshami
We are facing the same problem, did you get any fix to this issue??
Please advise
Hello Yousif,
I opened a case with Cisco, still, with no luck to solve it they need more time to investigate on the log but from the troubleshooting that I have done as below:
1- Check the password of the OS make sure doesn't have special characters like () or {} as explained on the command below by Jaim Valencia.
2- Check the firewall connectivity make sure there are no any blocking on any port.
for my case now Cisco TAC says the SUB server on the DR site is not able to create elm account on the PLM.
I will update you if we had any luck to solve this issue.
