CUCM v15 - VG224, VG310 y VG320
ednarvaez
Hi everyone
Do you know if VG224, VG310 y VG320 are supported by CUCM v15?
Thank you
Yes they are. We have a bunch of them and we’re on CM v15. For more details on this and other dependencies see this link Cisco Collaboration Systems Release Compatibility Matrix
Response Signature
6 Replies 6
Response Signature
Hi Roger
Thank you, do you know if three models are supported? I'm worried about model VG224
Yes all three are supported. Did you actually look at the link I shared?
Response Signature
Hi Roger,
Yes, I saw the link and I can see the VG224, VG310, and VG320 models, but isn’t there an issue if there’s no minimum or recommended version for the VG224? That’s what worries me a little
We have these three VG models in operational state in our system.
Response Signature
Excellent, that makes me feel more at ease. Now I’ll just check the firmware version I need for the devices
Thank you Roger
