CUCM V7.1 Lock Direct Calls on IP Phone
Mohamed_Saad
I want to make a pin code required when someone dials 9 or is trying to get direct line ...
the phone is already with direct line feature but I want authorized users only to log-in and be granted the line otherwise internal calls only and emergency are allowed ...
kindly advise
Joseph Martini
You can use extension mobility so that a user has to login to the phone with a username and pin, which will set a different profile on the phone that contains a different calling search space to allow external calls.  The default logged out profile can have a CSS that only allows internal calls.  Alternatively you can use Forced Authorization Codes (FAC) where a user would dial an external number and be prompted for a code to enter in order to be allowed to place the call.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00807d11d4.shtml
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsem.html
Joseph Martini
FOC Works like a sharm for me ...
Later when I have time I will try Extension mobility
thanks man
