CUCM v9 Licensing question
abraham23482
We have 6 global clusters connected to a centralized ELM. All clusters are on version 9.1.2. We mostly purchase CUWL Standard Licenses when we add more users.
We use Extension mobility globally and all users get a Jabber client as well. We associate the end user to the Jabber device. I know that a CUWL Standard license allows upto 2 devices per license. But we are not effectively utilizing it. Since we use EM we do not associate a user to a physical phone. So all the physical phones in our clusters goes in with an Enhanced license borrowed from CUWL Standard.
I was trying to understand what is the best practice while adding physical phones in this scenario. Attached is our usage report from ELM. Every now and then we go out of compliance and gets into a tough situation. Could someone please help me understand where we stand and what is the best way to go forward with this.
Abraham
2 Accepted Solutions
Dennis Mink
By the looks of it you have a whole bunch of people assigned with an enhance plus license, i.e using a device profile, plus something like  a CSF device/mobile Jabber.  is that correct?
you also have around 11k of standard licenses unused. these are used for adding single devices, so for instance a user that only has a desk phone, or an analog device.
check this link that explains the entitlement
https://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-licensing/C45_523902_11_9_licensing_aag_v5a_1.pdf
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
Chris Deren
+5 for Dennis for correct answer.
In addition CUWL Standard allows for up 10 devices assigned to a user not 2. For 2 you'd use Enhanced Plus license.  Sounds to me like you might be better off with just Enhanced licenses + voicemail licenses if users to not get more than 1 device as EM takes no license only defined device do.
Dennis Mink
Thanks Dennis and Chris
Chris Deren
