CUCM version to support integration Skype for Business 2016
wilsonsant
Frequent Contributor
Hi Guys,
I would like know what version CUCM support integration with Skype for Business 2016. I read any documentations, but, not is clear for me. My Customer have CUCM version 10.5.2 and appear (not I sure) that this version not have support. Could You to confirm, please.
Wilson
let me rephrase the question,
Do you want to make calls only between S4B endpoints and CUCM endpoints? In
this case what you need is a SIP trunk connecting them and this is
irrelevant on the version of CUCM.
Do you want to have IM, Group Chat, Chat Rooms, Directory Lookup, etc? In
this case you need full integration between S4B and CUCM/IMP using
federation and this is supported on version 11.5 for S4B 2016. Another way
is to federate using Expressway (instead of CUCM/IMP but these need to be
connected to expressway as well) which requires Expressway 8.9.1
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
Hi Wilson,
What kind of integration are you looking for. If you want call routing,
then version doesn't matter as you create a SIP trunk pointing to S4B. If
you are looking for federation, then you need IMP 11.5
Hi Mohammed al Baqari,
Thanks a lot for Your contact. I am sorry, but, I don´t knowledge Federation. What are the difference between this two conditions?
Thank You,
Best Regards,
Wilson
Thanks a lot for Your assistance and Your help.
Best Regards,
Wilson
