02-03-2017 05:32 PM - edited 03-17-2019 09:25 AM
Our organization will be moving the voice mail for the entire staff to Office365. In call manager I have to change the setting to point to the Office365 server. Is there a way to configure multiple directory numbers simultaneously. I need to make a change to the Voice Mail Profile Field under "Directory Number Setting". I have over 2000 voicemail directory numbers to make this change to. The screen shot I attached below shows the field that I have to update.
Solved! Go to Solution.
02-04-2017 08:52 AM
add/update lines, that's what you need to use.
02-03-2017 08:53 PM
Simply use BAT to change that, or if there's no profile, just choose the option to make the new one the system default.
02-04-2017 08:13 AM
Thanks for the reply Jaime. Am I missing something here? I do not see any option to make changes to directory number setting under BAT. Please advise.
02-04-2017 08:52 AM
02-04-2017 09:48 AM
Thanks, Jaime I see where to make the change.
02-04-2017 07:32 AM
Like Jaime said..
This is exactly what you would use BAT for..
Literally you can get that change done to all 2000 DNs in a min or two..
02-04-2017 08:13 AM
Thanks for the reply Andrew. Am I missing something here? I do not see any option to make changes to directory number setting under BAT. Please advise.
02-04-2017 08:38 AM
I'll login to BAT and give a quick run down in about an hour.
02-04-2017 09:52 AM
Andrew,
Jaime has pointed out how to get to the page to make this change.See path below:
Bulk Administration > Phones > Add/Update Lines > Update Lines. Thanks for responding.
