CUCM7: Attendant Console
Anil Sharma
Level 3
Level 3
Hello Everyone,
Could you please help me!!
As per the current setup:  I am using Directory numbers in Hunt group configuration of Attendant console pilot; instead of username and line number.
Want I want is : If no one is logged into Attendant console the call should go to voicemail instead of phones ringing
Is it possible with same kind of setup OR do i need to change the Attendant console design i.e using username and line number ??
Thanks for your advice.
Jaime Valencia
You'll need to change to the user/line approach.
Only with that config the AC will determine wheter to route calls or not based on the fact of your login status.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks for your advice..
