09-22-2011 02:24 PM - edited 03-16-2019 07:09 AM
I need more than 20 router filters each has two rules that area code and office code, and 20 entries to not exceed max 1024 characters. When I download the csv file, there are many fields and even truncate beause Excel limitation. Really painful to modifying the exported csv file.
Any way to create many router filters with csv file?
Thanks in advance,
09-22-2011 10:28 PM
The Excel sheet just creates a CSV. If you are happy you understand the format required you can create the CSV in something else easily - I'd use a decent text editor like jEdit (others like Notepad++).
Aaron
Please rate helpful posts...
09-23-2011 06:23 AM
Thanks the advise but my concern is router filter specific. other components are straightforward and I can easily udpate on CSV file but the route filter csv format is kind of mess-up and difficult to formating from original number pattern,,,
Advice please,
