CUCM85 and PLAR phone config
drominore
Not alot of recent information on this config but we did manage to get the 3905 series to do a PLAR to a door intercom device. All was working well except for a small delay between pickup and actual dialout. A different user was trying to reconfigure another 3905 and may have made a subtle, not obvious change to the Partition and/or CSS. At this time the PLAR phone now gets a dialtone on pickup and it will not auto-dial the intercom. If the user manually dials the intercom extension it will connect.
The partition has only two entries with one device in each; a CSS and a Translation Pattern. All looks just as it did before but obviously is not working like it did before. Any tips on how to diagnose what is happening? As I was raised on 4.0 and this is 8.5 I am hesitant to play around with settings, etc. unless advised to do so, especially in this PLAR configuration...
Mike
Rob Huffman
Hi Mike,
The 5.x, 6.x section of the attached doc will be compatible with
8.5 so you should be able to reverse engineer what has changed
or start over from scratch
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Cheers!
Rob
"What you don't have you don't need it now"
- U2
