08-14-2012 10:44 PM - edited 03-16-2019 12:43 PM
Hi Everyone,
I'd like to change the extension length from 3 to 4, however the CUCMBE 3K's GUI interface doesn't allow me to do that. I have consulted the administrator guide but it didn't even tell me how to change it.
As per the administrator guide:
"Select the value of the extension from the drop-down list. The values are from 3 to 11. The length of Main Number cannot be less than the value selected here.
You cannot update this field in the Cisco Business Edition 3000 Administrative Interface."
Does anyone know how to change extension length?
08-14-2012 10:54 PM
Please refer the section "Dial Plan Settings" in the below link,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe3k/8_6_1/system/03_dialplan.pdf
Hope it helps.
Anand
Pls rate helpful posts !!
08-14-2012 10:59 PM
Hello anchoudh,
Thanks for quick reply.
As what I have said on my first post that I checked the admin guide and it only says this.
08-15-2012 10:23 PM
There is only one way - reinstall BE3K.
