2599
joe.bennett
Participant
CUCMBE as NTP server
My CUPS server is complaining that the CM publisher's NTP isn't working. The publisher is a CUCM-BE and a show ip preferences shows that NTP is blocked by the firewall. It's synced fine to our internal NTP servers but won't let anything else sync to it which is tricky because CUPS insists on syncing to it. Any ideas how to enable NTP on the server?
Joe
15 REPLIES 15
Thanks for your help Fernando. I don't know that I can log a TAC case given that it's beta code. There is an update available so I will try that when I get a moment. I will raise the issue through the beta test channels. I agree that the problem is that cucm is refusing to open up the firewall ports for NTP although it does for other services.
Joe
Sent from my mobile.
Content for Community-Ad
