04-05-2011 08:26 AM - edited 03-16-2019 04:20 AM
I am working with a client that has a CUCMBE server installed, but now wants to migrate to a CUCM and a seperate Unity Connection Server. They want to reuse the current 7828 server for CUCM and are purchasing a new 7825 to run Unity Connection. I know there is no supported path to do a migration, per the installation guide I need to reenter all of the data into the new CUCM installation once that is up and running. But are there any recommendations to make this type of a migration easier and less likely to run into issues with the manual reentering of the data?
Any insight would be greatly appreciated.
Thank you,
Michael Putney
Solved! Go to Solution.
04-05-2011 08:35 AM
Your best option will be to use the Import/Export feature within BAT. You can export most - but not all - of the dial plan and devices through this method to CSV. These CSVs (wrapped in a TAR file) can then be imported on the new cluster.
04-05-2011 08:40 AM
Hi Michael,
Because you are moving from BE to a stand-alone Unity Connection you will be able
to use COBRAS for the Export/Import of CUC data
The following is a table of support version paths – for Unity restores of a Unity backup the rule is you must restore it to the same version of Unity or later. You cannot backup, say, Unity 5.0 and restore it onto a Unity 4.0(5) installation. Newer data objects and conversations etc… cannot be restored into the older database so this is not allowed.
Backed Up Version | Can be Restored To: |
Unity 4.0(5) | Unity 4.0(5), 4.1, 4.2, 5.0, 7.0, 8.0, Connection 7.x or 8.0 or 8.5 |
Unity 4.1 | Unity 4.1, 4.2, 5.0, 7.0, 8.0, Connection 7.x or 8.0 or 8.5 |
Unity 4.2 | Unity 4.2, 5.0, 7.0, 8.0, Connection 7.x or 8.0 or 8.5 |
Unity 5.0 | Unity 5.0, 7.0, 8.0, Connection 7.x or 8.0 or 8.5 |
Unity 7.0 | Unity 7.0, 8.0, Connection 7.x or 8.0 or 8.5 |
Unity 8.0 | Unity 8.0, Connection 7.x or 8.0 or 8.5 |
Connection 1.2 | Connection 7.x or 8.0 or 8.5 |
Connection 7.0 | Connection 7.0 or 7.1 or 8.0 or 8.5 |
Connection 7.1 | Connection 7.1 or 8.0 or 8.5 |
Connection 8.0 | Connection 8.0 or 8.5 |
Connection 8.5 | Connection 8.5 |
NOTE: Restores to Connection 7.x or later are supported only for stand alone installations – you cannot import backups into a co-resident (Business Edition) installations. You can do exports from a co-resident installation however, so you can migrate a co-resident to a stand alone server if you like.
NOTE: Unrestricted versions of Connection (those that lack high encryption capabilities) cannot allow message exports using COBRAS because the super user IMAP access needed by COBRAS for this works only over TLS/SSL which is not supported on unrestricted versions. Messages can only be extracted remotely from restricted (standard) versions of Unity Connection.
Some important things to notice in this table:
Cheers!
Rob
04-05-2011 08:35 AM
04-05-2011 08:40 AM
Hi Michael,
Cheers!
Rob
04-12-2011 01:50 PM
Thank you both. I used both suggestions and the migration has gone off very smoothly.
thank you very much.
Michael
