10-02-2012 01:39 AM - edited 03-16-2019 01:28 PM
Hi There,
I am trying to install a fresh CUCME/CME on 2901 router , the version of cme is 8.6
I have the cme-buddle on the root of the tftp installed on my PC.
Cisco Docs makes it so simple ;
archive tar /xtract source-url flash:/file-url
Could you please give us an example of the source-url part .
I am getting the error
%Error opening tftp://.......
Solved! Go to Solution.
10-02-2012 04:29 AM
cme-151-4Mv1.tar is the general folder
You have to issue the above command for each file that is in this folder
Example1:
open the cme-151-4Mv1.tar.There you will find many other folders
moh.tar file example
Then the command will be
archive tar /xtract tftp://10.10.10.1/moh.tar flash:
Example2:
May you find the below folder
7970-7971-sip.8-4-2S.tar
so the command will be
archive tar /xtract tftp://10.10.10.1/7970-7971-sip.8-4-2S.tar flash:
If some files are not .tar format and you want to convert it to .tar format then you can use this link or something else for the conversion
cc
10-02-2012 01:43 AM
archive tar /xtract tftp://tftp-ip-address/package-name.tar flash:
cc
10-02-2012 03:31 AM
Hi Chrysostomos1980,
what do you mean by package name?
I have tried this ,
archive tar /xtract tftp://172.16.27.5/cme-151-4Mv1.tar flash:
this is a full bundle, Is there any mistakes in the one above?
10-02-2012 04:23 AM
What tftp server are you using? Is the file present in the root directory of your tftp server? If you get error opening the file, its most likely you have not setup your tftp server properly
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
10-02-2012 04:28 AM
I am using Solar Winds, and Yes I have put the cme zip file on the tftp root?
I have started and restarted the tftp server.!!!
I have also rechecked the command, the syntax is also correct.
I see that the problem is with the tftp server, but not able to isoloate the problem,
I have confirmed that the my PC's firewall is off also..
10-02-2012 04:29 AM
Example1:
Example2:
cc
10-02-2012 04:44 AM
thanks chrysostomos1980
I will update you once I tried that,
10-02-2012 04:54 AM
10-02-2012 05:05 AM
Hi Mohammed
Great
Note:
After to xtract the files into flash and the files will be in directory (below is an example) then Pls remember to use this format for the tftp-server
tftp-server flash:/MEDIA/music-on-hold.au alias music-on-hold.au
tftp-server flash:/RINGTONES/Analog1.raw alias Analog1.raw
tftp-server flash:/RINGTONES/AreYouThere.raw alias AreYouThere.raw
In flash will like that:
Example in flash:
MEDIA
RINGTONES
05-09-2017 12:45 AM
Dear ,
Could you list to me the steps if I want to upgrade my telephony-service from 10.5 to 11.
If you give the link to download the related IOS or cme version It will more better. I want to do this upgrade for CISCO router 2901 IOS Version 15.5(1)T,.
05-09-2017 02:38 AM
You need to have CCO account download the tar file from cisco.com
05-09-2017 03:12 AM
here is the link to download tar file and as mentioned here you need a cisco CCO account to download from this page:
https://software.cisco.com/download/release.html?mdfid=277641082&softwareid=282786567&release=11.6&relind=AVAILABLE&rellifecycle=&reltype=latest
You need to check the compatibility matrix in the below link. and download the corresponding IOS versions:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
Link to download IOS:
https://software.cisco.com/download/release.html?mdfid=282774223&flowid=7438&softwareid=280805680&release=15.5.3M5&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Rajan
Pls rate all useful posts
