CUCME and ESRST Config Help
thilinar8
i am trying to setup E-SRST on Branch Router for CME on Main Office. Couldn't find a Single Document for this. can someone point me to right direction.
found some SRST config for CME, but those commands not working on E-SRST
i am running CME 12.2 and IOS XE 16.9.1 Fuji
7 Replies 7
jay.johnson1
Here's a brief video tutorial/series I put together and posted on Cisco's "Learning Network" a while back to demonstrate MGCP/PSTN/H.323/Trunk setup which also includes how to "fail over and back" with SRST:
Video Tutorial Series 7 (VoIP) MGCP/PSTN/H.323/Trunk Gateway Configuration
1) https://learningnetwork.cisco.com/docs/DOC-29511  PSTN Configuration
2) https://learningnetwork.cisco.com/docs/DOC-29606  Callmanager Configuration
3) https://learningnetwork.cisco.com/docs/DOC-29595  MGCP Router Configuration
4) https://learningnetwork.cisco.com/docs/DOC-29625  Trunk & Phone Configuration
5) https://learningnetwork.cisco.com/docs/DOC-29627  PSTN Dialplan Configuration
6) https://learningnetwork.cisco.com/docs/DOC-29703   H.323 Intra-Site Dialing
7) https://learningnetwork.cisco.com/docs/DOC-29697  H.323 Inter-Site Dialing
8) https://learningnetwork.cisco.com/docs/DOC-29698  POTS PRI Dialing
9) https://learningnetwork.cisco.com/docs/DOC-29699  SRST Failover
10) https://learningnetwork.cisco.com/docs/DOC-29708  MGCP Failover (Pt 1)
Jay
Certified: CCNA (R/S, Security, Voice), CCDA, CCNP (R/S)
Hi Jay,
Thanks for the documents.
i'll go through all.
most of the SRST commands not supported in ESRST
router is not giving any other option.
You cannot run CME and SRST at the same time.
What are you using CME and SRST for ? I mean what phones for CME and for SRST ?
Thanks for the reply.
i am using CME in main office and SRST for Branch office. Main office Power and Internet connections are not reliable. so, its dropping often.
Main office:- Cisco 4331 router with CME 12.3 and ISP SIP/ISDN
Branch office:- Cisco 4331
Phones:- 7945/7811/7832/8831
i found few CME/SRST configs but, New Version is E-SRST....none of the SRST commands are working. """" its keep saying this command deprecated use mode esrst.""""
Are you trying to run CME and SRST on the same router ? I wanted clarification around that. Where is your CUCM ?
No.....
solution is
[CME on Main Office]----VPN LINK---->>>[SRST on remote office]
Not supported. There is no concept of SRST in a CME deployment. SRST is something to be considered in a CUCM deployment.
