CUCME Attempted Registrations
jesus.lazcano
I have an issue with my 3945 CUCME Router, with 8 VG224 Analog Gateways
The router  throw me a console message that says:
Memory full, run clear telephony-service ephone-attempted-registrations to refresh the storage
When I enter the show ephone attempted-registrations I got the following.
VASCMXGWY#sh ephone attempted-registrations
Attempting Mac address:
Num    Mac Address         DateTime                          DeviceType
1            10:30:46 Mexico Tue May 15 2012      Unknown 83
2            10:30:51 Mexico Tue May 15 2012      Unknown 83
3            10:30:54 Mexico Tue May 15 2012      SCCP Gateway (AN)
4            10:30:56 Mexico Tue May 15 2012      Unknown 83
And continues ..so I think that the buffer got full .
I need help to identify the cause of this problem when I check the registration status of my VG224 all seems fine and registered.
Thanks.
paolo bevilacqua
If you enable debug tftp event, you should see the mac address of the device that is attempting to register.
You can also enable auto-registration to prevent the problem and indentify the device.
Hi Paolo,
Thanks for your response.
I have this output in the debug command
VASCMXGWY#
May 15 15:51:11.703: TFTP: Looking for VASCMXVG2.cnf.xml
VASCMXGWY#
May 15 15:51:13.071: TFTP: Looking for SKIGWEF489F2DE4.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGW00F13769B5.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGWEF489F2268.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGW00F137628F.cnf.xml
May 15 15:51:13.419: TFTP: Looking for VASCMXVG8.cnf.xml
VASCMXGWY#
May 15 15:51:14.227: TFTP: Looking for SKIGWEF489F09CC.cnf.xml
May 15 15:51:14.227: TFTP: Looking for SKIGWEF489F2E8E.cnf.xml
VASCMXGWY#
May 15 15:51:15.595: TFTP: Looking for SKIGWEF489F2F1A.cnf.xml
VASCMXGWY#
VASCMXGWY#
VASCMXGWY#
May 15 15:51:26.875: TFTP: Looking for VASCMXVG1.cnf.xml
VASCMXGWY#
May 15 15:51:31.871: TFTP: Looking for VASCMXVG5.cnf.xml
VASCMXGWY#
May 15 15:51:41.395: TFTP: Looking for VASCMXVG3.cnf.xml
VASCMXGWY#
May 15 15:51:49.303: TFTP: Looking for VASCMXVG4.cnf.xml
VASCMXGWY#
May 15 15:51:53.663: TFTP: Looking for VASCMXVG6.cnf.xml
VASCMXGWY#
VASCMXGWY#
May 15 15:52:13.127: TFTP: Looking for SKIGWEF489F2268.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGW00F137628F.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGWEF489F2DE4.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGW00F13769B5.cnf.xml
VASCMXGWY#
May 15 15:52:14.231: TFTP: Looking for SKIGWEF489F09CC.cnf.xml
May 15 15:52:14.231: TFTP: Looking for SKIGWEF489F2E8E.cnf.xml
VASCMXGWY#
May 15 15:52:15.595: TFTP: Looking for SKIGWEF489F2F1A.cnf.xml
VASCMXGWY#
I Have a question, Why is this happening if I see all the VG224 ports registered in CUCME
Im a using SCCP STCAPP
They have some "ccm config" commands left, remove them.
