01-19-2011 02:15 AM - edited 03-16-2019 02:57 AM
Hi all,
in a CUCME environment, is it possible for a 7945 for example, to change the order of blf and speed dials.
Because now, if i issue the command under ephone:
blf-speed-dial 1 954 label "XXX" device
blf-speed-dial 2 955 label "XYX" device
blf-speed-dial 3 957 label "XYZ" device
speed-dial 1 02108010101 label courier
speed-dial 2 0100 label police.
the device will first display the 2 speed dials and then the blfs no matter what.
Solved! Go to Solution.
01-19-2011 04:50 AM
You can do it in the latest version - CME 8.5
Phil
01-19-2011 04:50 AM
Phil
01-19-2011 07:20 AM
