CUCME COR
Michael Grann
I'd like to set up the following:
Phones 1-5 are allowed to call outbound to PSTN only via FXO ports 0/0 and 0/1.
Phones 6-8 are allowed to call outbound to PSTN vial FXO ports 0/0, 0/1, and 0/2.
Can someone please share a sample config of COR in CME to accomplish these?
TIA,
Mike
Terry Cheema
Michael as per your post the requirement is to restrict phones 1 to 5 from using port 0/2. Phones 6 to 8 can use all ports.
There are number of ways you can do. Try the below config:
     1)      Define the COR Lists
dial-peer cor custom
name PHONES1to5
name PHONES6to8
dial-peer cor list PH1to5
member PHONES1to5
dial-peer cor list PH6to8
member PHONES6to8
dial-peer cor list ALLPH
member PHONES1to5
member PHONES6to8
     2)      Apply COR lists to the appropriate dial-peers
Under the dial-peers for ports 0/0 and 0/1:
corlist outgoing PH1to5
Under the dial-peers for port 0/2:
corlist outgoing PH6to8
     3)      Apply COR lists to the ephones
Under the ephones 1to 5 assign the cor list:
ephone-dn 1
number 2001
cor incoming PH1to5    << This will block them from going out dial-peer with port 0/2 as it has a different COR
Under the phones 6 to 8 assign the cor list:
ephone-dn 6
number 2006
cor incoming ALLPH   <<< This COR can call from all the dial-peers 0/0, 0/1, 0/2. Alternatively even if we don’t assign anything for phones 6 to 8 they will be able to use all the dial-peers.
The ephones without a cor list assigned will have unresticted access. So if there is a ephone9 without any cor list it will be able to call through all the dial-peers.
Hope That Helps.
Terry
Terry Cheema
name PHONES1to5
name PHONES6to8
member PHONES1to5
member PHONES6to8
member PHONES1to5
member PHONES6to8
ephone-dn 1
number 2001
ephone-dn 6
number 2006
Hope That Helps.
Terry
Terry, that looks perfect. Thanks so much.
-Mike
No Problem Michael. I am glad i was able to help.
