07-06-2018 07:38 AM - edited 03-17-2019 01:09 PM
Hi Guys,
I would like know is possible install to CallManager Express in virtual machine. I always to see CUCME installed/configured in Voice Gateways.
Wilson
Solved! Go to Solution.
07-06-2018 08:22 AM
07-06-2018 07:45 AM
UC Products that are supported virtualized are in the virtualization wiki, along with the requirements. OR, you can also refer to the CME IOS compatibility matrix for supported platforms, what is listed, is what is supported.
07-06-2018 07:56 AM
Hi Jaime Valencia,
Thanks a lot for Your contact. I verified the two conditions that You said, but, there are not this information.
Wilson
07-06-2018 08:22 AM
