CUCME in SRST Mode- Internal dialing not working when phones are in SRST
CUCME in SRST Mode-
Cisco IP Phones if they lose their connection to a remote Primary CUCM  which can occur if the WAN connection to the main site is down.Phones are in SRST mode. As soon as phones are in SRST mode, they cant dial internal dialing by last 4 digitis of the extension.
For EG:
DN's are created in the range of 80801XXX
When phones are in SRST, user trying dialing last 4 digit as 1XXX to reach extension # 80801XXX which is not working. please let me know if you require any further info on this.
CUCME SRST config:
telephony-service
srst mode auto-provision none
srst ephone template 2
srst ephone description CME SRST : Jul 04 2012 10:40:50
authentication credential admin cisco
max-ephones 265
max-dn 600
ip source-address 10.229.21.5 port 2000
no service directed-pickup
system message "SRST Mode: Cisco Unified CME'
url services http:///10.229.21.6/common/login.do
url authentication http:///10.229.21.6/authentication/authenticate.do
cnf-file location flash:
load 7916-12 B016-1-0-3.sbn
load 7916-24 B016-1-0-3.sbn
load 7945 SCCP45.9-1-1SR1S.loads
load 7965 SCCP45.9-1-1SR1S.loads
load 7975 SCCP75.9-1-1SR1S.loads
time-zone 39
date-format dd-mm-yy
dialplan-pattern 1 80803... extension-length 4 extension-pattern 3...
dialplan-pattern 2 80801... extension-length 4 extension-pattern 1...
keepalive 10
voicemail 80801999
mwi relay
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
create cnf-files version-stamp 7960 May 09 2013 16:13:5
12 Replies 12
Hi Karthikeyan,
Any dial peers configured? And Translation rules?
Kind Regards
Below dial-peers has been configured for the incoming calls to go to phone's ,while phones are registered to CUCM.
The problem here is when phones are in SRST mode, internal calling between phones doesnt work.
dial-peer voice 2 voip
description Connection For CCMSUB
destination-pattern 8080....
session target ipv4:10.242.0.51
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
preference 1
session target ipv4:10.242.0.50
voice-class codec 1
voice-class h323 1
no vad
Actual DN's are configured in the range of 80801XXX & 80803XXX , we've translation pattern in CUCM to translate calling number from 1XXX & 3XXX to 80801XXX & 80803XXX.
Whenever the phones are in SRST, the user are not able to make internal calls using 1XXX  & 3XXX.
You must then to create a Voice translation rule in the GW:
Like:
voice translation-rule 1
rule 1 /\( ^1...$\)/ /8080\1/
rule 2 /\(^3...$\)/ /8080\1/
voice translation-profile TransSRST
translate called 1
And aply to a dial-peer:
dial-peer voice 902 voip
description SRST
translation-profile outgoing TransSRST
destination-pattern .T
session target ipv4:X.X.X.X
You can use test translation-rule 1 XXXX  (f.e 3111) to check if the translation works correcty.
Regards!
Daniel M.
If am applying the above dial peers, which wil disturb the inbound calls coming into router,  when the phones are registered with Call manager.
It will conflicts with below dial peers.
voice-class codec 1
voice-class h323 1
no vad
preference 1
voice-class codec 1
voice-class h323 1
no vad
Hi.
When registered on cucm, which is the dn of ip phones on remote site?
When in srst do a show ephone registered | in dn and please post the result.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
DN's - 80801XXX & 80803XXX
DN's - 80801XXX & 80803XXX range
If you dont want to use translation rules then you can use number expansion..
conf t
num-exp 1... 80801...
num-exp 3... 80803...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Karth,
Try to think that SRST is a survivable mode, so he can't reach the Translation patterns from CUCM so u must or use num-exp or Translation rules in a Internal dial-peer to this works.
Daniel,
I have created num-exp in router but it didnt worked when phones are in sRST
Can you please send the output of
then do a test call and send debug voip ccapi inout
