CUCME Paging FXO - Valcom V9964
DaveX4285_2
Troubleshooting a paging intergration where the Paging port will hang off hook after the initial call is disconnected and the only way to fix is do a shut/no shut on the voice-port. The voice-port configuration is
voice-port 0/1/0
supervisory disconnect dualtone pre-connect
supervisory answer dualtone sensitivity high
timing hookflash-out 50
timing sup-disconnect 750
caller-id enable
Haven't worked on many paging intergrations previously. Has anyone worked with the V9964 adapter in the past? Or have a sample Valcom FXO paging intergration to share.
Thanks!
paolo bevilacqua
Is the paging system calling into CME?
In that case, dualtone and pre-connect will not work for sure. You need mid-call, and the exact tone configuration.
If is CME calling into into paging, no configuration is needed, but you can update IOS to gain robustness and new features.
Mike Jennings
DaveX4285 - Did you find a workable solution for this yet?  I am having the *EXACT* same issue.  Client pages pretty heavily and every 2-3 days the port gets stuck off-hook and has to be reset.  They have been rebooting the v-9964 to clear the port.
Any advice on your fix would be appreciated.
Thanks!
I also have the same issue here.
dangquangminh@vnpro.org
CCIE#11897
dangquangminh@vnpro.org CCIE#11897 6016 Tillsdows Dr, Mississauga,ON Canada L5N4M3
