06-01-2015 07:53 AM - edited 03-17-2019 03:11 AM
I am using CUCM ver 9 and using network backup. From Last week i am getting error "TAR file not created" and it seems the full backup is not completed.
Please advice.
06-01-2015 08:05 AM
Make sure you have enough space, and try a manual backup to see at which point it fails.
06-01-2015 05:22 PM
At what point is it failing?
Are you using DNS or IP addresses in your backup device?
06-02-2015 12:52 PM
IP
06-01-2015 09:31 PM
Hi himdobriyal1,
beyond what Jaime Valencia and Andrew West already said ... before a Manual Backup, remove all the old backups from the destination folder.
Hope this helps.
06-02-2015 12:56 PM
this is remote site so not possible to do manual back as well virtual environment do not support tape drive i guess. Moreover i did google and got to kknow drf service need to restart but not sure that it would be correct to do it in live environment
06-02-2015 01:08 PM
Hi himdobriyal1,
try to point the Manual Backup for you local computer ( In http://<CUCM-IP-Addr>/drf/Backup > Backup Device) ... just for a test.
In http://<CUCM-IP-Addr>/ccmservice > Tools > Control Center - Network Services > select the CUCM > restart the following services (it could be done in live environment):
Cisco DRF Master
Cisco DRF Local
Hope this helps.
