CUCS 6 Replication Question
fgasimzade
Level 4
Level 4
Hello everyone!
I've  been checking my cluster's replication status for last month, it has  always been 393 counts and never changed. Status of replication is 2  which means Good, but I cannot understand if replication counts does not  change does it mean that replication does not occur?
Thank you in advance
Rob Huffman
Hi there,
You are fine here
The "number of replicates" is set during the initial cluster (Pub/Sub)
replication build and would only possibly change if the replication had to be re-built.
As long as the count is 393 on both and the status is 2 on both you are good
to go! I just revisited our cluster set up via RTMT and noted the "number of replicates"
is @ 427 where it has been since the initial build.
Number of Replicates Created
This counter displays the number of replicates that were created by Informix for the DB tables. This counter displays information during Replication Setup.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/serviceability/rtmt/guide/2xcucrtmtagpdf.pdf
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Rob Huffman
Hi there,
You are fine here
Cheers!
Rob
Thank you, Rob!
My concern was because the last time we had to switch off our Publisher, the phones got registered to the one of Subscribers, but DB information was not up to date so some phones displayed incorrect extension numbers, names etc. The things is that I did not check the replication status before before we switched of the Publisher.
Anyways, replication status is good now, is there any chance I could check when the last replication took place?
Hi there,
First off, you are most welcome
Have a read through this excellent CSC doc, it has lots of great info
on replication report/cli commands/queries etc;
https://supportforums.cisco.com/docs/DOC-13672#Cisco_Unified_Reporting__Database_Status_Report
A really simple way to verify replication from time to time is to log onto the Sub gui and
make a simple change on a device. Then log into the Pub gui and check to see that the
change was replicated over. Then reverse the change via the Pub and check via the Sub
to ensure the reverse change is true there.
Cheers!
Rob
Thank you for the link you provided
I have just made changes on Sub and my ip phone received the changes as well as I can see the changes on Pub
One question left - in Database Status report there is
g_cucs01_ccm6_1_2_1000_13    2 Active   Local           0
g_cucs02_ccm6_1_2_1000_13   11 Active   Connected       0 Jul 12 12:42:18
g_cucs03_ccm6_1_2_1000_13   19 Active   Connected       0 Jul 12 12:42:19
g_cucs08_ccm6_1_2_1000_13   18 Active   Connected       0 Jul 15 15:57:30
What does these July 12 and July 15 mean?
