CUCXN Backups Fail
D Mo
Cisco Unity Connection version: 10.5.2.18900-15.
When logging in, I receive this:
The last backup of Cisco Unity Connection failed.
When checking DRS history, I get this:
2019-10-18-03-00-46.tarNETWORKWed Oct 23 03:00:04 EDT 2019ERRORSCHEDULED - CiscoCUCS-SFTP-Sched10.5.2.18900-15PLM,CUC,CONNECTION_MESSAGES_UNITYMBXDB1,CONNECTION_DATABASE,CONNECTION_GREETINGS_VOICENAMES,CONNECTION_HTML_NOTIFICATION
If I am reading this correctly, the backups ran with an error but the backups of the modules ran. When I check the current status for the error message I see this:
ERROR: Backup Completed... Unable to start backup because there are no local agents connected. This may be due to Master or Local Agent being down.
When navigating to CUC Serviceability > Tools > Service Management, I do not see Master or Local Agent like in CUCM.
How do I activate the Master and Local Agent for Unity Connection?
HARIS_HUSSAIN
I would suggest restarting Master and Local Agent on Unity Publisher and restart Local Agent only on Subscriber. & try again.
utils service restart Cisco DRF Master
utisl service restart Cisco DRF Local
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Yort Mantup
Level 4
Level 4
you will need to navigate to Cisco Unified Serviceability.  Tools --> Control Center - Network Services.  Choose your server and scroll down to the end.  You should then see the two services under Backup and Restore Services.   I recommend if you need to start the services to do it from the CLI.
HARIS_HUSSAIN
Haris
After restarting DRF Master and Local through CLI. I was able to run a manual backup successfully.
