CUE 2801. How/Can a VM box play greeting and hang up so caller does not leave a message?
cliveferguson
Hi there,
We have a CUE 2801 (revision 7.0).
The customer would like one of their phones to forward to Unity Voicemail and play a greeting but does not want the caller to be able to leave a message, they want it to hang up after the greeting.
Is this possible and how can it be done via command line?
Your help and advise is much appreciated,
Fergo
Aaron Harrison
You can configure the 'extended absence' greeting - this plays the specified greeting and does not take a message.
This doc is for 8.x but I think it's supported on 7 : http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/unity_exp/rel8_6/user/guide/voicemail/enu/86vu-enu.pdf
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
7 Replies 7
Aaron Harrison
Aaron
Sounds like a great plan...and it will give the user full control of it themselves ;)
thanks a million!
In the end that did not work out for me. On this Cisco Unity Express 2801 version 7, it does not have an "extended absence" greeting, it only has Alternative Greetings which prompts and allows users to leave messages.
Anyone else have a better solution to this query please?
thanks!
Rob Huffman
Hi Fergo,
I just wanted to add this bit to the great tips from Aaron here (+5 "A")
Configuring an Announcement-Only Mailbox
Beginning in version 7.1, you can configure announcement-only mailboxes. These mailboxes can play the user greeting and disconnect the call only; they cannot take any messages from callers or send messages.
Announcement-only mailboxes enable you to:
Perform any operations that can be performed on a greeting in personal mailboxes, such as recording or deleting.
Use all the new greeting types introduced by the multiple greeting feature. For more information, see the Configuring Multiple Greetings.
Configure a General Delivery Mailbox as an announcement-only mailbox.
Also, announcement-only mailboxes:
Cannot be part of everyone's list (9999)
Are counted against the mailbox license
Have a default size of 5 minutes when they are created, but the default size can be modified later
Because announcement-only mailboxes cannot send or receive messages, you cannot:
Create distribution lists for them
Configure notification devices for them
Therefore announcement-only mailboxes cannot:
Have messages addressed to them
Have notifications cascaded to them
Receive broadcast messages
Subscribers can log in to announcement-only mailboxes using either the TUI, VVE, or IMAP. However, there is no reason to use IMAP to log into announcement-only mailboxes because they do not contain messages.
The following features are available only for personal mailboxes and cannot be used with announcement-only mailboxes:
Message expiration time
Message size
Fax configuration
The following operations are available only for personal mailboxes in the TUI and VVE and cannot be used with announcement-only mailboxes:
Playing new, saved, or deleted messages
Sending messages
Setting message parameters, such as configuration lists or notification devices
SUMMARY STEPS
1. configure terminal
2. voice mailbox owner name type announcement-only [size seconds]
3. end
4. show voicemail detail mailbox name
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmadmin_book/vmconfig.html#wp1042523
Cheers!
Rob
Will that work for Cisco Unity Express?
thanks
Hi Clive,
Yes, the excerpt is from the CUE (Cisco Unity Express) config guide :) If you paste the url I posted in a new browser window you can read the complete guide.
Cheers!
Rob
Thanks for your help and relies.
I have discovered my Unity Express Software Version is 3.2.2, so the above solutions do not work for me.
Sorry for misleading you, my version of Call Manager Express is 2801 V7.
