CUE 7.1 Failure The backup Thread interrupted: Operation timeout
tdudas
Beginner
Beginner
Hi All,
I'm facing with an issue on CUE 7.1
After backup procedure I got the following:
Data: Failure The backup Thread interrupted: Operation timeout
Configuration: Success
HistoricalData: Success
So it seems CUE can reach the sFTP serverm also make success backups for Configuration and HistoricalData, but the Data has error??
Has anyone got this issue?
Thanks!
Tibor
V.Naveen Kumar
Beginner
Beginner
which sftp server you are using..??
Hi Kumar,
It is a freeFTPd 1.0.11
I have several CUE modules 7.0, 7.1
When I did backups different size of backup files were created for the modules:
CUE7.0
395M
CUE 7.1
494M
46.8M
30M
93M
but in all cases I got the following error:
configuration and/or historical data were succes
Has this sFTP/FTP sw have any limitation of uploading (downloading) files?
Tibor
