CUE 9.0.5 GUI language german?
alig.norbert
Enthusiast
Enthusiast
Hi all,
I was able to install the langauge package on the CUE (German) and works so far.
The GUI still has the US language. Can this be changed for the mailbox user?
Thank you,
Norbert
Unfortunately that is not possible. Web page is solely based on US English. The additional languages installed will affect greetings/vm access, auto attendant etc. only.
5 Replies 5
R0g22
Are you trying to set the language for a particular user ?
You need to go to Configure >> User >> Click on the user >> Language parameter >> Choose German
Yes, already done but the GUI menu still shows US.
The same with IE and firefox. Language package German_DE is installed on IE.
The language installed does not affect the GUI. It will affect VM access, auto-attendant etc. Why do you want the users to access the GUI ? Is it for Web inbox ?
Yes, for the /user web access/box.
