05-18-2012 08:54 AM - edited 03-16-2019 11:14 AM
I have a UC500 with an AIM-CUE and I get many errors when I attempt to boot it up, so I am trying to install version 7. I have a Vlan that acts as the default gateway on the router, and am utilizing the IOS DHCP server, which successfully hands out IP's addresses to clients. From my workstation I can ping the default gateway on the vlan and the service-module.
My default gateway is 10.225.25.1
My workstation IP is 10.225.25.3
The bootloader IP address is 10.225.25.5
However, I can not ping anything from the bootloader command prompt of CUE, including the loopback, which is why the TFTP file transfer is failing. I don't have many configuration options, anyone have any ideas?
05-20-2012 02:23 AM
You are using the wrong image, for UC500 CUE you must use uc500 CUE files, not NM files.
05-21-2012 09:05 AM
Yea, I realized that after my last post. I upgraded with the UC500 files, but I get a bunch of errors.One of which is
Error in opening the file /usr/trace/trace.tcmd: Permission denied
ReiserFS: hda1: warning: vs-5150: search_by_key: invalid format found in block 163888. Fsck?
ReiserFS: hda1: warning: vs-13070: reiserfs_read_locked_inode: i/o failure occurred trying to find stat data of [3974 3975 0x0 SD]
ReiserFS: warning: is_leaf: free space seems wrong: level=1, nr_items=13, free_space=28 rdkey
Waiting 881 ...ReiserFS: warning: is_leaf: free space seems wrong: level=1, nr_items=13, free_space=28 rdkey
CUE shouldn't take this long to boot, I think I have a hardware issue.
05-21-2012 10:23 PM
The CUE CF card is faulty, you can try replacing it with another third party one.
That requires opening the chassis cover.
Please remember to rate useful posts clicking on the stars below.
