CUE Editor 7.0.3
jeanzhao1987
I used cue editor 7.0.3 write a simple script try to apply in CUE 8.x AA, but it has no response when I press as the menu instroction. Does anyone have any idea about this? Is cue editor 7.0.3 not compatible with CUE 8.x? Which version should I used?
By the way, if use the web GUI editor come with CUE 8.x, it is very limeted to do the requirement my client need.
Thanks very much.
Rob Huffman
Hi Jing,
There are 8.x script editors available. Here is the path for
CUE 8.5.1;
Unity Express Utilities-8.5.1
You may find this doc helpful as well
http://docwiki.cisco.com/wiki/Cisco_Unity_Express_--_Custom_Script_Editor_FAQs
Cheers!
Rob
Thank you very much for your help
