CUE GUI page not working
fei he
Level 2
Level 2
I was trying to open CUE GUI page from IE with no joy. Any idea?
I can access CLI with no problem at all.
11 Replies 11
Naiman Ghori
Please check your configuration you should have the below commands into your cme.
#config terminal
#ip http server
#ip http path flash:
or
ip http path flash:/gui
or
ip http path flash:/cme/cme/cmegui
#telephony-service
#web admin system name admin password 123 secret 5
Please rate if helpful.
Hi Naiman
those config already in CME CLI, pls see below:
sh run | s ip http
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
web admin system name EMCCMEAdmin secret 5 $1$B9U3$d/iBBte/6jQYHJobVeqOg/
web admin customer name admin password 8264
BTW, it is CUE GUI stop working NOT CME.
Hi Fei he
I am with the same problem in my Customer. Did You solved this problem? If yes, That You found?
Wilson
Configure the file privilege as 0. in the global config mode.
This should help.
Venkitesh
Hi Venkitesh
CUE GUI used to working but stop working now.
I am pretty now to CUE, can you specify where you can config file privilege as 0. in global? Is this apply to CME CLI or CUE CLI?
Fei
Gaurav Purohit
try reloading the CUE. Also, whats the error you are getting? have you tried any other browser? has anything changed? is there any possibility of a firewall?
Hi Gaurav
There is no firewall between and i tried various browser as well, all timed out -
Internet Explorer cannot display the webpage.
As far as i know, there is no config change.
Lets see how does it go with reload CUE. It will take a while to get it done.
rgds
Hi Gaurav
reload cue does not make any improvement at all.
i will have security team to check whether traffice for port 80 has been blocked or not.
but just weired, as far as i know, no config change, GUI was still working 1 wk back.
rgds
Can you ping CUE ?
what type of CUE is this? NM, NME, AIM? from the CUE, can you ping your PC? can you confirm that the CME and CUE are on same subnet? do you have option to specify the default GW for CUE as CME?
Hi Garav
1.CUE type is ISM-SRE-300-K9.
2.Ping test past from PC to CUE but CUE to PC failed. (PC is on 10.x.x.x subnet, CUE is NATed on 192.168.25.x subnet, CUE real IP is on 172.18.91.x subnet).
3. Both CME/CUE are on same subnet 172.18.91.x
4. Default GW for CUE is configured as CME real IP 172.18.91.x.
