04-26-2012 07:18 AM - edited 03-16-2019 10:50 AM
i want to import users from CUCM to CUE 8.6. In the user details i have a user device profile and set the primary extension. But in the CUE import i cannot set the primary extension. Only manual after import.
If i associate a physical device the primary extension is shown but this is the logged out extension and not the UDP extension.
It is not possible to import user with primary extension from a UDP ?
Cheers
Jason
12-04-2012 05:16 AM
Jason,
I am having the same issue here with CUE 8.6.4.
Did you manage to get this resolved?
We have experienced this with just the UDP`s, fixed phone configurations give no problem.
12-04-2012 05:27 AM
hi egoppel,
no sadly no luck with this. If you found a solution let me know. :-)
Jason
