Highlighted
Cue issue with forward to voicemail.
I have a issue with CME + CUE when forwarding calls to voicemail.
When receive an incoming call from SIP Provider number, the correct phone associated starts ringing. After 10 seconds the phone forwards the call to the CUE voicemail pilot number, but who calling hear ringing endless. Seems that CUE is not able to respond.
I'm sure that the matter is the process of forwarding associated to incoming SIP calls, because I have tried this:
incoming call from PSTN is forwarded correctly to voicemail.
incoming call from SIP directed to CUE voicemail (VM administration number from PSTN) is successful (I can hear Cue asking my ID).
Thank you for help
8 REPLIES 8
Highlighted
Re: Cue issue with forward to voicemail.
Please attach CME and CUE config.
Highlighted
Here is the output of "debug ccsip messages" of an inbound call from SIP Provider "voip.eutelia.it".
Oct 14 14:34:44.950: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 83.211.227.21;branch=z9hG4bKb45b.e97348b5.0,SIP/2.0/UDP
62.94.71.98:5060;rport=61765;x-route-tag="tgrp:Slot6";branch=z9hG4bK5AD745ECB
To: <>;tag=29657134-1907
Date: Wed, 14 Oct 2009 14:34:44 GMT
Call-ID: 8D09ACD7-B80511DE-87D591AB-C6312517@62.94.71.98
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO,
REGISTER
Allow-Events: telephone-event
Remote-Party-ID: "Gianluigi" <340>;party=called;screen=no;privacy=off
Contact: <>
Record-Route: <83.211.227.21>
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct 14 14:34:54.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 302 Moved Temporarily
CSeq: 101 INVITE
Diversion: <>;reason=no-answer;counter=1
Contact: <>
Content-Length: 0
Oct 14 14:34:55.018: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:***IDCALLED***@192.168.0.249:5060 SIP/2.0
CSeq: 101 ACK
User-Agent: SPS EUT RM GW 02 (0.9.6 (i386/linux))
Content-Length: 0
At this point the call keeps ringing for the caller and not forwarded to voicemail.
In attach you will find the cme and cue configuration.
Highlighted
Hall of Fame Master
Try
voice service voip
no supplementary-service sip moved-temporarily
Highlighted
I've tried with this result:
Oct 14 16:28:49.511: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 501 Not Implemented
Via: SIP/2.0/UDP 83.211.227.21;branch=z9hG4bK852d.09e461c5.0,SIP/2.0/UDP 83.211.2.218:5060;rport=58994;x-route-tag="tgrp:Slot7";branch=z9hG4bK4FB8A312A5
To: <>;tag=29CDBA24-1956
Date: Wed, 14 Oct 2009 16:28:39 GMT
Call-ID: 76C2D8AF-B81511DE-8CAD92F2-3F8F6970@83.211.2.218
CSeq: 101 INVITE
Reason: Q.850;cause=65
Content-Length: 0
Oct 14 16:28:49.555: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 ACK
User-Agent: SPS EUT RM GW 03 (0.9.6 (i386/linux))
Content-Length: 0
The caller hear Error Tone and is not forwarded to Voicemail.
Highlighted
I am assuming that your voicemail pilot is 6100. Try entering these commands in the voicemail dial-peer:
mailbox-selection orig-called-num
voice-class sip outbound-proxy ipv4:
The problem may be that that the number it is forwarding to is being sent back to the registrar, who does not recognize the number, assuming that 6100 is not a DID. Who knows what they do with it. By entering the command voice-class sip outbound-proxy in the dial-peer, it forces the number to be redirected to the CUE module.
Highlighted
Sorry, forgot to ask. Is your service provider acting as an outbound proxy as well?
I've applied your suggested command, but with no result.
here the debug ccsip:
Oct 15 08:38:41.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 83.211.227.21;branch=z9hG4bK2f31.66c0b2a6.0,SIP/2.0/UDP 83.211.2.216:5060;rport=56053;x-route-tag="tgrp:Slot6";branch=z9hG4bK6517E9252B
To: <>;tag=2D45CD58-1E63
Date: Thu, 15 Oct 2009 08:38:41 GMT
Call-ID: F9B3A0E7-B89C11DE-8D3EBF13-D44B072@83.211.2.216
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <>
Content-Length: 0
Oct 15 08:38:51.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 INVITE
Contact: <6100>
Content-Length: 0
Oct 15 08:38:51.327: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 ACK
User-Agent: SPS EUT RM GW 01 (0.9.6 (i386/linux))
Content-Length: 0
I don't know if my provider act as an outbound proxy.
What I think is:
When I recieve a call from PSTN the CME forwards correctly the call to Voicemail. Instead, during an incoming SIP call the CME leaves the forwarding process to Service Provider.
There is any way to force the SIP forwarding process to working only locally?
Highlighted
Beginner
Thanks for this post I've
Thanks for this post I've been struggling with this issue of the global outbound-proxy command for ages.
I've applied "voice-class sip outbound-proxy ipv4:" to my voicemail DP and it has kept the call local even when "session target ipv4:" existed and did not help.
Though "mailbox-selection orig-called-num" did not help and I'll have to find a way to preserve the called num/ext as it doesn't go to the appropriate mailbox when <messages> is hit or when outside calls go to voicemail the call is terminated as there is no specified mailbox.
