167
Explorer
CUE KVM on 4331 ISR
I am trying to design a CME/CUE solution using a 4331 ISR. I'm starting with the UC bundle ISR4331-V/K9 and I've added the FXS and FXO NIMs I need.
I'm having trouble finding out what I need to order for CUE. I understand that CUE in this environment will need to run on a virtual machine either in an ESXi environment or on the ISR as a KVM. I want to run it on the ISR itself. What I can't figure out is what I need to order to support this. Is there additional hardware I need or does the 4331 already have the Service Container functionality baked in? Also, do I need any DRAM (4 GB default) and/or flash (4 GB default) upgrades? Lastly, do I need to order any storage?
Thanks in advance.
Everyone's tags (4)
1 REPLY 1
Re: CUE KVM on 4331 ISR
You need a NIM-SSD (this is the actual extended storage that will host and run the application) if you are concerned about the part number. Then download the OVA for service container for vCUE from CCO.
Also review the vCUE installation guide for memory requirements. You need at least 8 GB if I remember correctly else the IOS won't allow you to configure virtual service.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Content for Community-Ad
August's Community Spotlight Awards
