Hi Expert,
I've the below setup, CUE integration with UCM. User are prompted to enter the ID prior to enter password.
Understand that this is due to CUE can't recognize the calling#. Internal DN is 4 digit while EPNM is set
to E164 with "+".I've configured both the primary DN and primary E164 under user profile on CUE,the system
still prompting for ID.
The GW is MGCP controlled,so don't think xlation will work. I did try on transformation pattern and
set the correct CngPTP on CTI-RP and CTI port but still doesn't work.
Am i missing out anything?
