08-08-2014 12:05 PM - edited 03-16-2019 11:40 PM
Getting this error when uploading a script to my V3.0.3 CUE. There are currently 8 system scripts and I have upload 3 more for total of 11. I need to add one more. Is there a parameter somewhere that I can use to increase the limit?
TIA,
Diego
Solved! Go to Solution.
08-08-2014 08:42 PM
There is a hard limit depending what CUE module you use, you need to check for your version and your module
08-08-2014 08:42 PM
08-10-2014 10:15 AM
I wasn't able to find what the particular limit for my CUE module is but it turned out I didn't need all the scripts that I thought I needed.
Thanks Jaime.
Diego
